glyphosate and 24D mix Expiration?
   / glyphosate and 24D mix Expiration? #11
....I never had any problems.
Problem would happen if you were to use the tank AFTER spraying 2,4D (you clean like you normally would) then use the sprayer on a sensitive crop like like cotton. You *might* get it clean enough but it takes just molecules of 2,4D to screw up some plants.
If you are using the tank to kill one thing vs. killing another thing - you don't even need to clean it. I guess the OP needs to state what else his plans are for the tank...
Grass can handle 2,4D google says the normal rate for 2,4D on perennial grasses; "Use 2 to 4.2 pints of product per acre per application". That's why you never had a problem.
I'm guessing most of us just use the tanks for killing only... the research station I worked at had separate sprayers for 2,4D since they killed thousands of dollars of research plots one year.
   / glyphosate and 24D mix Expiration? #12
Glyphosate (Roundup) will kill most actively growing plants, so good cleaning after that chemical is important if you want to spray 2-4-D on the lawn to kill broadleaf weeds.
   / glyphosate and 24D mix Expiration? #13
I agree with you somewhat but I was assuming, a near empty tank after RoundUp would only leave a trace amount of it. After you refill the tank with water for a 2,4D spray, that trace amount would not effectively hurt a thing. Now the (full strength) residue left in the spray boom, that is another story!!! Yes, clean the tank....
   / glyphosate and 24D mix Expiration? #14
Agree. Just a triple rinse and flushing the boom would be sufficient.
Hustler super Z zero turn (A56859)
Hustler super Z...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2023 CHEVROLET 4500HD CAB AND CHASSIS (A58017)
2023 CHEVROLET...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2000 Sterling L7501 T/A Drill Rig Truck (A55973)
2000 Sterling...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
