Glow plugs.
/ Glow plugs. #1
duckhunter27
Dannebrog , NE
Bobcat CT 335
I have a CT 335 my glow plug light started not coming on when I turn the key on if it's warm out it seems to come on and work fine but if it's cold it will not come on. Any ideas what could be going on I was wondering if it might be a relay. Thanks
/ Glow plugs. #2
Do you know the glow plugs are not working when light isn't coming on? Not likely, but maybe just a loose bulb? My CT235 light does not come on in hot summertime or after running a while and then recranking. I suppose there is some sort of heat sensing that controls the light. However, your situation seems to be just opposite.
/ Glow plugs.
They are not working tractor won't start when light doesn't come on in winter.
/ Glow plugs. #4
I believe your preheat relay is on the firewall (3rd one in on right hand side). Many of those relays are identical. Might try swapping and see if it makes any difference.
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
2007 Freightliner M2 112 Tri-Axle Dump Truck (A66736)
2007 Freightliner...
2013 PETERBILT 367 FLATTOP SLEEPER TRUCK (A67714)
2013 PETERBILT 367...
