glow plugs
/ glow plugs #1
rexnord
Muskego, Wisconsin
Mahindra 2015 4wd
I have a Mahindra 2015 4wd tractor that uses a nkg-724u glow plug 8 volt. Does anyone know of a replacement for this glow plug. The ones from the dealer are around $50.00 each.
/ glow plugs #2
I don't, sorry...but why would such a new glow plug need to be replaced already?
/ glow plugs #3
I had a 2615HST and found the same problem. The plugs for mine were made by NGK and sold only to dealers. My glow plugs were not even listed on the NGK site. I replaced mine 3 times over a 10 year period. I heard they failed due to the glow plug timer cycle being too short. Mahindra had an upgrade kit that included new plugs and timer. I bought the kit and replaced mine. It was plug and play easy to replace. I think the upgraded plugs were rated for higher voltage (10 volts). I sold my 2615 almost 2 years ago but they are still working according to the guy who bought it.
Here's the link for the upgrade. I bought mine from Lawalls (a member here).
http://www.tractorbynet.com/forums/...5095-installing-glow-plug-conversion-kit.html
Other than the upgrade you can check with your local NAPA. They may be able to match the length and threads. If they can go with a 10V plug and it shouldn't burn out so fast.
/ glow plugs
After doing much research I have found a replacement for the NGK 724U. It is a NGK y107Y the only difference is it is a 8.5 volt Tractor starts fine.
Cost $6.93 cents each instead of $45.00 to $50.00 each from the dealer.
Challenger MT700 Series Tractor Parts Manual (A63117)
Challenger MT700...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A59912)
2012 INTERNATIONAL...
1993 Ford F-150 Ext. Cab Pickup Truck (A61573)
1993 Ford F-150...
KUBOTA BT1973 - 17 1/2" EXCAVATOR BUCKET (A64280)
KUBOTA BT1973 - 17...
JOHN DEERE 7100 4R PLANTERS (A63291)
JOHN DEERE 7100 4R...
