glow plugs
/ glow plugs #1
rexnord
Muskego, Wisconsin
Mahindra 2015 4wd
I have a Mahindra 2015 4wd tractor that uses a nkg-724u glow plug 8 volt. Does anyone know of a replacement for this glow plug. The ones from the dealer are around $50.00 each.
/ glow plugs #2
I don't, sorry...but why would such a new glow plug need to be replaced already?
/ glow plugs #3
I had a 2615HST and found the same problem. The plugs for mine were made by NGK and sold only to dealers. My glow plugs were not even listed on the NGK site. I replaced mine 3 times over a 10 year period. I heard they failed due to the glow plug timer cycle being too short. Mahindra had an upgrade kit that included new plugs and timer. I bought the kit and replaced mine. It was plug and play easy to replace. I think the upgraded plugs were rated for higher voltage (10 volts). I sold my 2615 almost 2 years ago but they are still working according to the guy who bought it.
Here's the link for the upgrade. I bought mine from Lawalls (a member here).
http://www.tractorbynet.com/forums/...5095-installing-glow-plug-conversion-kit.html
Other than the upgrade you can check with your local NAPA. They may be able to match the length and threads. If they can go with a 10V plug and it shouldn't burn out so fast.
/ glow plugs
After doing much research I have found a replacement for the NGK 724U. It is a NGK y107Y the only difference is it is a 8.5 volt Tractor starts fine.
Cost $6.93 cents each instead of $45.00 to $50.00 each from the dealer.
2025 SDLGC100 6 Passenger Electric Cart (A60352)
2025 SDLGC100 6...
2025 Swict 72in. Bucket Skid Steer Attachment (A61567)
2025 Swict 72in...
832632 (A61166)
832632 (A61166)
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
Ratchet Straps (A61569)
Ratchet Straps...
