Glow plug wiring help needed
/ Glow plug wiring help needed #14
I have a L48 and the glow plug light will come on and some times flicker while running. Can you tell or show me the location of the timer, controller, and relay? I don't mind buying the parts to keep it original, but would also consider the cheaper fix with hints and pics on where and how to install. Thanks in advance..
/ Glow plug wiring help needed #15
The glow plug relay is constantly powered by the key switch, the controller applies ground to it 's coil, that closes the contacts in the relay powering the glow plugs.
What causes the glowplug circuit to turn off? A temperature sensor or timer?
rScotty
/ Glow plug wiring help needed #16
rScotty
I assume its a timer due to the fact that in real cold weather ill cycle it a few times for better starting.
/ Glow plug wiring help needed #17
rScotty
The circuity in the controller uses a signal from engine coolant temperature, (see reference # 11 at the Bottom of the schematic), to establish a time to keep the glowplug relay energized. The glow plugs get very hot Very fast... they do Not need to be 'on' for very long... If you replace the controller with a manual switch, remember Short duration energizing will do the job, too much on time and you risk burning them up... KennyV
/ Glow plug wiring help needed #18
Just a follow up to say thanks for you guys help. The glow plug controller was faulty. I decided I would rather have a toggle switch to control the glow plugs with rather than a new controller.
I picked up a 3 position toggle switch (one position is momentary) DPDT plus a weather cover ($17 total) and with the help of KennyV's wiring diagram wired it in a Auto-Off-Hand configuiration.
Auto- leaves all in original condition
Off- drops power to the glow plug control
Hand- (momentary) drops power to the glow plug control and completes
ground circuit to glow plug relay to operate glow plugs
Works great and someday when I pick up a new controller I can just change that out and it will work normally if I want.
Jerry
hi Jerry how are im new to all this I have a L2900 I was wondering if you help me on how you did you wiring I like to do the same as you did.Thank You
Aggy
Rooster Weathervane (A55853)
Rooster...
1005 (A61166)
1005 (A61166)
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2018 Bobcat T770 (A60462)
2018 Bobcat T770...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2000 Sakai SV505 (A60462)
2000 Sakai SV505...
