Glow plug wiring help needed
/ Glow plug wiring help needed #1
jerrykn
Hi Guys,
I was fortunate to get a good deal on a L35, It only has a couple of issues. The main one is electrical. First problem was a faulty alternator, after reading here I ordered a replacement from Pats small engines.
I think what caused the Alt to fail is the glow plug controls. Most of the time the glow plug light (and plugs too) stays on all the time. I think this has caused the alt to run overloaded all the time and damaged the alternator.
Today the glow plugs didn't come on untill I pulled the dash and knocked the relays a bit, now it seems to stay on all the time again.
From searching here it seems there must be a timer that is supposed to shut the glow pulgs off.
I am looking for the location of that control. It looks like there is also a Glow plug relay.
Does anyone have the wiring diagram for these and the relay/timer location?
I just picked this up this week so I don't have a manual yet-Is there any online manuals?
Once I get the information I will see just what is wrong and figuire out if I will replace the timer or just rewire it to a momentary switch I will manually use to heat up the glow pulgs thru a relay.
Thanks
Jerry
/ Glow plug wiring help needed #2
You may want to bypass the relay and timer and make your own set-up to manually use the glow plugs only as needed. I have done this a few times. Use a heavy relay/solenoid (the existing one may work, or a new 80-100 amp rated relay) a normally off momentary contact switch and wire it to the solenoid/relay. This allows you to control how much you glow plug and when. I found it works much better than any automated system.
On edit: switch http://order.waytekwire.com/productdetail/M37/44006
Solenoid: http://order.waytekwire.com/productdetail/M37/77020
Exactly what I was thinking atgreene,
I've got an account at Grainger so I can pick up a weather proof switch and relay if I need one.
What I would like is to have the wiring diagram and timer location so I can rewire without tracing all the wires out behing the dash.
Jerry
/ Glow plug wiring help needed #4
On the Grand L's (similar - maybe identical glow plug control) the starter switch is turned until the glow plug indicator comes on and then later goes off, then the switch is turned further to start.
The parts list for the L3600 shows a timer T0070-31410 ($72) and a controller 16415-65660 ($62) These two are mounted back-to-back to the glow plug relay 16415-65600 ($26). All three pieces are mounted with 2 bolts inside the body behind the dash panel on the right side. The coolant temperature sender on the engine might be the problem - 16415-83040 ($23).
Depending on what's defective, a simple glowplug/starter switch without any relays or timers might be a cheaper fix. The older Kubota models used a simple 3-position switch to send power to the glow plugs and/or the starter. The L345 switch is 37150-32200 ($35) plus knob 37150-32210 ($5) - It is wired direct to the glow plugs in one position and in the other it powers the starter circuit too. (On these models the glow plugs also get power whenever the starter runs)
Kubota parts lists are available by email from Tractorsmart.com
Thank You rbargeron,
I appreciate the info and part #'s.
Since I don't have any wiring diagrams I can check out the relys etc. and compare to the part #'s you have given.
It will help a lot.
Jerry
/ Glow plug wiring help needed #6
Jerry...
This is the layout on Grand L's. I think rbargeron is right, should be the same...
I reduced the file sizr so they will fit. KennyV.
KennyV, you the man.
Just a follow up to say thanks for you guys help. The glow plug controller was faulty. I decided I would rather have a toggle switch to control the glow plugs with rather than a new controller.
I picked up a 3 position toggle switch (one position is momentary) DPDT plus a weather cover ($17 total) and with the help of KennyV's wiring diagram wired it in a Auto-Off-Hand configuiration.
Auto- leaves all in original condition
Off- drops power to the glow plug control
Hand- (momentary) drops power to the glow plug control and completes
ground circuit to glow plug relay to operate glow plugs
Works great and someday when I pick up a new controller I can just change that out and it will work normally if I want.
Jerry
/ Glow plug wiring help needed #9
Jerry,
I'm glad to hear you are up and going
If you can, post a schematic of your change for those that may want to do the same instead of springing the $70 for a controller. Kenny
/ Glow plug wiring help needed #10
Jerry...
labeled parts
/ Glow plug wiring help needed #14
I have a L48 and the glow plug light will come on and some times flicker while running. Can you tell or show me the location of the timer, controller, and relay? I don't mind buying the parts to keep it original, but would also consider the cheaper fix with hints and pics on where and how to install. Thanks in advance..
/ Glow plug wiring help needed #15
The glow plug relay is constantly powered by the key switch, the controller applies ground to it 's coil, that closes the contacts in the relay powering the glow plugs.
What causes the glowplug circuit to turn off? A temperature sensor or timer?
rScotty
/ Glow plug wiring help needed #16
rScotty
I assume its a timer due to the fact that in real cold weather ill cycle it a few times for better starting.
/ Glow plug wiring help needed #17
rScotty
The circuity in the controller uses a signal from engine coolant temperature, (see reference # 11 at the Bottom of the schematic), to establish a time to keep the glowplug relay energized. The glow plugs get very hot Very fast... they do Not need to be 'on' for very long... If you replace the controller with a manual switch, remember Short duration energizing will do the job, too much on time and you risk burning them up... KennyV
/ Glow plug wiring help needed #18
Jerry
hi Jerry how are im new to all this I have a L2900 I was wondering if you help me on how you did you wiring I like to do the same as you did.Thank You
Aggy
17308SFL (A61569)
17308SFL (A61569)
2018 Bell B30E 30 Ton Articulated Dump Truck (A60352)
2018 Bell B30E 30...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2025 BrushFox XHD-78HF 78in Hydraulic Rotary Brush Cutter Skid Steer Attachment (A61567)
2025 BrushFox...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2006 Freightliner Auger Truck (A63118)
2006 Freightliner...
