Glow plug not working
/ Glow plug not working #1
RWD123
2021 Kioti ck2610h
Good day
Have a couple issues but first issue trying to figure is why glow plugsare not working. Tractor has rebuilt engine with new glow plugs. Noticed in another thread someone posted a picture and in it shows two 70 amp Handouk relays. My tractor has both plugs but nothing is plugged in them are these for the glow plugs? Tractor runs fine once started. 60amp fuse is good and glow plug light comes on.
/ Glow plug not working #2
I see nothing about troubleshooting you've done. Do you have voltage at the glow plugs when the glow plug light is on? I'd start there. If you have voltage the new glow plugs may be bad. If you have no voltage you need to determine why.
Just found someone posted the wiring schematics in another thread, the one on the left in the picture is the glow plug relay. Jumpered pin 30 and 87 for 10 seconds and tractor fired up almost instantly, just need to order a relay now.
/ Glow plug not working #4
The large box is the display unit. It controls alot of functions including glow plugs. But glad you determined it was the relay. Ikeep a few relays as spare parts.
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2026 Electric Tricycle (A64194)
2026 Electric...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
