GLOW PLUG INDICATOR LIGHT
/ GLOW PLUG INDICATOR LIGHT #1
zues
I have a 3410 and the glow plug light does not work. I bought the tractor used, so I am not sure if the light ever worked. I turn the key on for 25 seconds and the tractor starts everytime. If I turn the the key on and start for the first time without waiting, the tractor will crank for a long time. I took the dash out and replace the bulb with a new bulb that does work.
The bulb is good but the light does not come on. The tractor runs fine, with no glow plug light.
/ GLOW PLUG INDICATOR LIGHT #4
25 seconds is just way too long to have to wait for auto ignition to occur. Get a multimeter and your tractors electrical schematic. Start at the glow plugs or fuse block and work your way through the circuit to see whats open or shorted. Its a simple process of elimination. You can do this.....
2019 Ford Fiesta SE Hatchback (A64557)
2019 Ford Fiesta...
PALLET OF AXLE TAKE OFF'S & CYL (A64278)
PALLET OF AXLE...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A67148)
2015 FREIGHTLINER...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
