GLOW PLUG INDICATOR LIGHT
/ GLOW PLUG INDICATOR LIGHT #1
zues
I have a 3410 and the glow plug light does not work. I bought the tractor used, so I am not sure if the light ever worked. I turn the key on for 25 seconds and the tractor starts everytime. If I turn the the key on and start for the first time without waiting, the tractor will crank for a long time. I took the dash out and replace the bulb with a new bulb that does work.
The bulb is good but the light does not come on. The tractor runs fine, with no glow plug light.
/ GLOW PLUG INDICATOR LIGHT #4
25 seconds is just way too long to have to wait for auto ignition to occur. Get a multimeter and your tractors electrical schematic. Start at the glow plugs or fuse block and work your way through the circuit to see whats open or shorted. Its a simple process of elimination. You can do this.....
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
NEW HOLLAND PULL TYPE ROLL BAR HAY RAKE (A64278)
NEW HOLLAND PULL...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64556)
Interstate 20ft...
