Global Warming?
Status
Not open for further replies.
/ Global Warming? #1,501
From my bro recently....
In addition to the cold and warm phases, the new climate curve also exhibits
a phenomenon that was not expected in this form. For the first time,
researchers have now been able to use the data derived from tree-rings to
precisely calculate a much longer-term cooling trend that has been playing
out over the past 2,000 years. Their findings demonstrate that this trend
involves a cooling of -0.3°C per millennium due to gradual changes to the
position of the sun and an increase in the distance between the Earth and
the sun.
"This figure we calculated may not seem particularly significant," says
Esper, "however, it is also not negligible when compared to global warming,
which up to now has been less than 1°C. Our results suggest that the
large-scale climate reconstruction shown by the Intergovernmental Panel on
Climate Change (IPCC) likely underestimate this long-term cooling trend over
the past few millennia."
But read the whole thing... a honest report for once...
Climate in northern Europe reconstructed for the past 2,000 years: Cooling trend calculated precisely for the first time
/ Global Warming? #1,502
How does that negate what was happening in Iceland and Greenland? I totally fail to see the logic. Just because some areas had one thing at a certain point while others had the opposite within a reasonable time, does not prove one over the other.
I mean any person that claims others are not open minded should at least wonder when the very people that started AGW say things like;
Again, let me restate my position on GW/CC. I'm not especially concerned whether it is provable or not. In fact I've said before here that to know 100% for sure we would need a control group, that is we would need to see the planet simultaneously with and without man's influence. This, of course, is not possible.
So, is the Alaskan town's perma-frost melting because of CC or not? We can make hypothesis and we can collect data but we can not be 100% sure, although there are people who believe it is occurring.
My view is that we address world pollution which is occurring and causing devastating damage to this planet. We could debate GW until our ears fall off and let's say we proved it 100%, what would we have to do next? We would have to address the pollution that is causing it. So let's cut to the chase and work on our planet. Now, who doesn't want to hear that? Do you think the oil companies and Massey Coal want to change the way they do business? I don't.
Deciding whether GW exists is not what is happening here, what is happening here is that we don't want to make changes to our messy life style. If we can cast a shadow on CC than we can go on life as usual and that is exactly what corporate energy wants. That's why the API spends big bucks lobbying congress. That's why we have unscrubed coal stacks acidifying our oceans.
You're proud to be from the south? Well how do you feel about Massey Industries raping the people and land of WV? One of the poorest states and one of the wealthiest companies. Don Blankenship walked away with lots of millions of dollars, the people of WV walked away with higher cancer rates.
Rob
/ Global Warming? #1,504
Now take all that, warming/cooling argument and try to prove that is all happening because of man is burning fossil fuels. They are all non sequitur.
HS
Burning fossil fuels are massively damaging the planet, as I have shown and stated. That's a given and that is what we have to address.
Rob
/ Global Warming? #1,505
Rob
Sorry but no such thing has been proven by anyone. 'Massively' is a strong word my friend. On the other hand, it is possible that burning fossil fuel is bad but then it can be argued that a volcanic eruption is every bit as bad -- do we ban volcanoes then?
/ Global Warming? #1,506
Coal & Electricity
Total World Electricity Generation by Fuel (2006)
Source: IEA 2008
*Other includes solar, wind, combustible renewables, geothermal & waste
Modern life is unimaginable without electricity. It lights houses, buildings, streets, provides domestic and industrial heat, and powers most equipment used in homes, offices and machinery in factories. Improving access to electricity worldwide is critical to alleviating poverty.
Coal plays a vital role in electricity generation worldwide. Coal-fired power plants currently fuel 41% of global electricity. In some countries, coal fuels a higher percentage of electricity.
Coal in Electricity Generation
South Africa 93% Poland 92% PR China 79%
Australia 77% Kazakhstan 70% India 69%
Israel 63% Czech Rep 60% Morocco 55%
Greece 52% USA 49% Germany 46%
Source: IEA 2010
The importance of coal to electricity generation worldwide is set to continue, with coal fuelling 44% of global electricity in 2030.
How is Coal Converted to Electricity?
Steam coal, also known as thermal coal, is used in power stations to generate electricity.
Coal is first milled to a fine powder, which increases the surface area and allows it to burn more quickly. In these pulverised coal combustion (PCC) systems, the powdered coal is blown into the combustion chamber of a boiler where it is burnt at high temperature (see diagram below). The hot gases and heat energy produced converts water – in tubes lining the boiler – into steam.
The high pressure steam is passed into a turbine containing thousands of propeller-like blades. The steam pushes these blades causing the turbine shaft to rotate at high speed. A generator is mounted at one end of the turbine shaft and consists of carefully wound wire coils. Electricity is generated when these are rapidly rotated in a strong magnetic field. After passing through the turbine, the steam is condensed and returned to the boiler to be heated once again.
The electricity generated is transformed into the higher voltages (up to 400,000 volts) used for economic, efficient transmission via power line grids. When it nears the point of consumption, such as our homes, the electricity is transformed down to the safer 100-250 voltage systems used in the domestic market.
Efficiency Improvements
Improvements continue to be made in conventional PCC power station design and new combustion technologies are being developed. These allow more electricity to be produced from less coal - known as improving the thermal efficiency of the power station. Efficiency gains in electricity generation from coal-fired power stations will play a crucial part in reducing CO2 emissions at a global level.
Efficiency improvements include the most cost-effective and shortest lead time actions for reducing emissions from coal-fired power generation. This is particularly the case in developing countries where existing power plant efficiencies are generally lower and coal use in electricity generation is increasing. Not only do higher efficiency coal-fired power plants emit less carbon dioxide per megawatt (MW), they are also more suited to retrofitting with CO2 capture systems.
Improving the efficiency of pulverised coal-fired power plants has been the focus of considerable efforts by the coal industry. There is huge scope for achieving significant efficiency improvements as the existing fleet of power plants are replaced over the next 10-20 years with new, higher efficiency supercritical and ultra-supercritical plants and through the wider use of Integrated Gasification Combined Cycle (IGCC) systems for power generation.
A one percentage point improvement in the efficiency of a conventional pulverised coal combustion plant results in a 2-3% reduction in CO2 emissions.
coal electricity, coal power plants - World Coal Association
/ Global Warming? #1,508
Coal & Electricity
Source: IEA 2008
Source: IEA 2010
Coal is first milled to a fine powder, which increases the surface area and allows it to burn more quickly. In these pulverised coal combustion (PCC) systems, the powdered coal is blown into the combustion chamber of a boiler where it is burnt at high temperature (see diagram below). The hot gases and heat energy produced converts water in tubes lining the boiler into steam.
The coal industry has been making clean up claims for years but you don't pour billions of dollars into DC to clean up coal stacks, you do it to reduce pollution fines... it worked!
Facts on the Pollution caused by the US Coal Industry
A typical-sized 500 megawatt coal-fired electricity plant in the United States puts out each year:
1. 3.7 million tons of carbon dioxide. Carbon dioxide (CO2) is the main greenhouse gas, and is the leading cause of global warming. There are no regulations limiting carbon dioxide emissions in the U.S.
2. 10,000 tons of sulfur dioxide. Sulfur dioxide (SOx) is the main cause of acid rain, which damages forests, lakes and buildings.
3. 10,200 tons of nitrogen oxide. Nitrogen oxide (NOx) is a major cause of smog, and also a cause of acid rain.
4. 500 tons of small particles. Small particulates are a health hazard, causing lung damage. Particulates smaller than 10 microns are not regulated, but may be soon.
5. 220 tons of hydrocarbons. Fossil fuels are made of hydrocarbons; when they don稚 burn completely, they are released into the air. They are a cause of smog.
6. 720 tons of carbon monoxide. Carbon monoxide (CO) is a poisonous gas and contributor to global warming.
7. 125,000 tons of ash and 193,000 tons of sludge from the smokestack scrubber. A scrubber uses powdered limestone and water to remove pollution from the plant痴 exhaust. Instead of going into the air, the pollution goes into a landfill or into products like concrete and drywall. This ash and sludge consists of coal ash, limestone, and many pollutants, such as toxic metals like lead and mercury.
8. 225 pounds of arsenic, 114 pounds of lead, 4 pounds of cadmium, and many other toxic heavy metals. Mercury emissions from coal plants are suspected of contaminating lakes and rivers in northern and northeast states and Canada. In Wisconsin alone, more than 200 lakes and rivers are contaminated with mercury. Health officials warn against eating fish caught in these waters, since mercury can cause birth defects, brain damage and other ailments.
9. Trace elements of uranium. All but 16 of the 92 naturally occurring elements have been detected in coal, mostly as trace elements below 0.1 percent (1,000 parts per million, or ppm). A study by DOE痴 Oak Ridge National Lab found that radioactive emissions from coal combustion are greater than those from nuclear power production.
10. A 500 megawatt coal-fired electrical plant burns 1,430,000 tons of coal, uses 2.2 billion gallons of water and 146,000 tons of limestone a year.
/ Global Warming? #1,509
You're kidding right?
http://www.epa.gov/acidrain/education/site_students/whatcauses.html
Sources of Acid Rain
"Acid rain is caused by a chemical reaction that begins when compounds like sulfur dioxide and nitrogen oxides are released into the air. These substances can rise very high into the atmosphere, where they mix and react with water, oxygen, and other chemicals to form more acidic pollutants, known as acid rain. Sulfur dioxide and nitrogen oxides dissolve very easily in water and can be carried very far by the wind. As a result, the two compounds can travel long distances where they become part of the rain, sleet, snow, and fog that we experience on certain days.
Human activities are the main cause of acid rain. Over the past few decades, humans have released so many different chemicals into the air that they have changed the mix of gases in the atmosphere. Power plants release the majority of sulfur dioxide and much of the nitrogen oxides when they burn fossil fuels, such as coal, to produce electricity. In addition, the exhaust from cars, trucks, and buses releases nitrogen oxides and sulfur dioxide into the air. These pollutants cause acid rain."
I can go into the acidic effects on the oceans, barren lakes in the Catskills ,etc. etc. And when you're done here view the post to Crashes coal pollution that I replied to.
Actually massively isn't strong enough. Devastatingly massive destruction is more like it.
Rob
/ Global Warming? #1,510
No matter what side you are on, greenie, warmer or denier, there are dozens of web sites to support your position.
None of them Prove anything - Just someones or groups opinion.
Hate to repeat myself but here goes.
If coal was as bad as the last post says, everyone close to Tucson or N. AZ would have cancer or already dead.
With All that acid rain nothing would be growing - Yet there are major farms all over the place around here. Strange????
A few more little facts or quotes.
I've got my solar panels and they are making me money. Very Good - They are guaranteed for 25 years. Maybe not so good.
They were made in the USA -- Maybe not so good. 17+ Solar mfg. given gov $$$ have gone out of business. That includes GE.
GE spokes man says when solar power proves practical and cost efficient they may start over.
Glass panels require huge amounts of Heat to mfg. To the best of my knowledge they all use fossil fuel.
Plastic panels are made out of crude oil.
Glass can be shattered by a hale storm. 5 Years in the sun at my place and the plastic panels will be toast.
Solar does not work to well covered with snow. Not a problem, go heaters to melt it off. Opp's Need a whole bunch of them Lead Acid batteries. How do you blow the clouds away when the whole sky turns gray.
Don't use lead acid batteries, got some of those lithium batteries. Good deal They are a little worse hazard than the lead acid. Bet they contain some of that nasty cadmium, mined in China.
Enough for 1 Rant.
/ Global Warming? #1,511
Rob
While West Virginia is not a southern state, per their own choice, I'm against corporate abuse in WV, Michigan, NC, or CA. Maryland by the way, is a southern state though most don't realize it. I'm from North Carolina, though. :D
I agree on pollution, it's devastating where left unchecked and if the UN really is interested in real problems and not politics they would heavily sanction India, The Philippines, China and all the other unregulated polluters of the world!;)
/ Global Warming? #1,512
You forgot to mention it is the USA number one exported product( some one making a lot of money in the name of energy independence), as well as the cleaning technology used for those country's that receive our exported coal.
Also due to coal we have plenty of dead lakes in the upper Ohio valley due to the emissions.
/ Global Warming? #1,513
If China or India wanted to buy our rotten meat, then we should sell it to them. If they choose to pollute all their waterways with it it's not our responsibility as sellers. However, as part of the world community it is their responsibility to clean up their own pollution. If every industrialized country were per capita as clean as we are, the world would be a much cleaner place. We cannot shoulder the burden alone while others go about pollution business as usual.
/ Global Warming? #1,514
Just a little note on China.
China produces around 5 times as much coal as the USA. It is the largest producer (miner ) of coal on the planet.
Also the largest polluter on the planet.
They do want our crude oil, but I don't think they want our coal.
/ Global Warming? #1,515
You think you are free? Tomorrow corporate oil decides to charge you 25 dollars a gallon for your gas and 50 dollars a gallon for home heating oil. What do you do? You are owned by a system. Freedom is an aspect of the individual, not the society and certainly not the government. Freedom is in autonomy, if you can establish autonomy you have a chance at individual freedom. When corporate oil has a noose around your neck the last thing you are is free. When pharmaceutical companies lock you into drugs for your entire life you are not free. Think about that.
We live in a corporate oligarchy. You can't have corporations pouring billions of dollars (bribes) into a government and have that government be a government of the people.
Addressing world pollution is an individual action, that is how it will change.
"Massive change is entirely dependent upon individual action"
MK Gandhi
Do I think I'm free? Nope. Do I have more Liberty then citizens of other countries? Yes absolutely -- and I've been to 13 of them and lived in a few (so not just visiting).
The rest of your point is lost on me. I mean I get your 'big oil is bad' point but then do you not also believe 'big government is bad' too? Or do you think evil men only serve in corporations and only good and honest men serve in government?
I'd rather take my chances with Big Oil then Big Government by the way -- after all, I can choose to walk and use wood heat but I can't choose not to pay taxes to support some cooks idea that we can save the world from evil simply by redistributing wealth and giving up liberty.
/ Global Warming? #1,516
This big issue is not global warming or climate change. The climate is never static it is always changing. The main issue is "man" effecting the climate? The definitive answer to that no matter how you feel about change is "there is no evidence" to prove man is effecting climate change or even could. That issue is settled science. Now the argument is "is it cooling or warming" no one really knows yet.
HS
Agreed!
/ Global Warming? #1,517
But.... But..... But..... If we do not support big government, how are the libs going to be able to mandate all of us into submission?
/ Global Warming? #1,518
http://www.tractorbynet.com/forums/...89d1341713316-global-warming-evidence_co2.jpg
Dang facts.
Houstonscott - the thing absent from all of your posts, hailing "facts", are facts. Because you say something does not make it true (you state no facts nor do you offer proof) - it just makes it your opinion and those are rather cheap. And cheap comes from people that have "no" credentials. Post a fact and surprise the dickens out of us.
Status
275 Gallon Chemical Container (A64127)
275 Gallon...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2022 EZ-GO ELITE...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
KMC Hi-Residue Plow (A64127)
KMC Hi-Residue...
