GL3710HST Loader problem
/ GL3710HST Loader problem #1
Bass
Kubota GL3710HST
The bucket on my loader creeps up (turns up) by itself. regardless of the position its in. I also think the bucket dump motion is slower than I remember it to be. Any ideas?
/ GL3710HST Loader problem #2
Sounds like your valve is not returning to neutral position… if you have a cab, then you have a remote lever on the valve, the problem can be in the cable length adjustment. Good starting place before you check inside the valve. KennyV.
No cab. it's a joy stick. I put a few drops of oil on the pistons thinking they just needed some lube to return to netural, but that didn't don anything.
Problem was water got into the controller valve and rusted up. Once cleaned and packed with grease, everything works well! Be careful when pressure washing.
2024 John Deere 5075E Tractor Loader (A63116)
2024 John Deere...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2012 WESTERN STAR  4900 SB (A63569)
2012 WESTERN STAR...
6 Row Do-All (A64047)
2023 John Deere 8R 280 Tractor (A63109)
2023 John Deere 8R...
2022 LINCOLN  VANTAGE 549X (A63569)
2022 LINCOLN...
