GL3710HST Loader problem
/ GL3710HST Loader problem #1
Bass
Kubota GL3710HST
The bucket on my loader creeps up (turns up) by itself. regardless of the position its in. I also think the bucket dump motion is slower than I remember it to be. Any ideas?
/ GL3710HST Loader problem #2
Sounds like your valve is not returning to neutral position… if you have a cab, then you have a remote lever on the valve, the problem can be in the cable length adjustment. Good starting place before you check inside the valve. KennyV.
No cab. it's a joy stick. I put a few drops of oil on the pistons thinking they just needed some lube to return to netural, but that didn't don anything.
Problem was water got into the controller valve and rusted up. Once cleaned and packed with grease, everything works well! Be careful when pressure washing.
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
