Get An Engine Heater!!
   / Get An Engine Heater!! #61
Yes, diesels are not as easy to start as gas engines when cold, that is a given.
Block heaters are included for worst case conditions, even in light trucks.
I don't find a need for mine until single digit temps and even then it doesn't seem to matter if I forget.
My point is that if it used to start fine at (pick a set of conditions) when new, but now only starts under those conditions PLUS some extra heat, then the heat is compensating for a problem.
That problem is not "fixed" with heat, it is masked.
There is another thread on this in the Branson/Century/Zetor forum where a member ignored a cold start problem for too long and it really CO$T him.
It was that tale of woe that prompted me to tear my (similar, but different model engine) glow plugs and injectors out for a look.
I will be doing the same on my other tractors, some of which are a little "reluctant" to start, not HARD or difficult, but not as easy as when they were new.
I think they SHOULD BE as easy to start as they were when new.
re decompression devices / exhaust valve lifters; Diesels DO NEED cranking speed and decomp was an easy way of getting the engine spinning fast with 30s/40s/50s era technology starters and batteries.
Shorter stroke engines, more cylinders, better starters and batteries have changed most of that.
1972 Chevrolet Cheyenne 10 4x4 Pickup (A57453)
1972 Chevrolet...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2011 20ft. Anderson Lowbed Trailer (A56859)
2011 20ft...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
1998 6ft. Utility Trailer (A56859)
1998 6ft. Utility...
