RobS
Super Member
The double male danger is in the exposed terminals. They would be hot if the other end is plugged into a live outlet. Female terminals won't nail you if they are hot.
gemini5362 said:Robs beat me to it. double ended male plugs are always dangerous for the reason that he stated.
I do like some of the ideas in this thread. I am going to be wiring a sub panel in my garage. After reading this I might do some work on my house wiring. If I put a transfer switch into the Sub Panel and then put an enclosed male plug in a small panel that you would open up and plug an extension cord from your generator into. That should be a safe way to hook up to the generator. If I run some of the wiring to the lights in my bedrooms, bath kitchen etc and to a few limited receptacles I believe that in the event of an electric power outage I could slide the manual transfer switch off of Line power and then plug in the generator. That would solve the problem of having to turn off circuit breakers when I use the generator. If I leave certain lights such as hall lights etc off of the subpanel then I would know when the power came back on and since the other items are on a transfer switch I would not have to worry about problems with power coming on while I am using the generator. Does anyone see any problems with this ?
RobS said:It's pretty simple and I'm confident the wife or older son can make it work if I am away. That was another consideration for me that lead to the transfer switch.
rback33 said:I am not too worried about this aspect. 1) I don't think my wife could start our genny anyway. It pulls hard. Thank heavens it always starts on the second pull. 2) I can make 1 call to any of my buddies and they would be right there to fire it all up.
RonMar said:You might also have a look at this site... This is the most cost effective method I have come across. If you want to see an example, go to your local Home Depot, Loews or a local electrical supply house and look at their whole house electrical panels. They usually have an interlocked generator-ready panel on display/on the shelf... This company makes UL approved retrofit kits for existing panels. The FAQ section on their website has diagrams and more info on how it works.
Generator InterLock Kit
Ford850 said:While this isn't the least expensive, it looks like the easiest to have installed and an absolute no brainer to switch to backup power supply. It's an atuomatic switch installed at the meter base, and comes with the cord to plug to your generator. It's a very safe option that requires no wiring changes to your panel. My electric company sells these and installs them for free.
GenerLink.com - About GenerLink - The easy way to connect a home generator
That sums it up. It's all about risk. How much insurance do you have in case you electrocute a lineman? In my case, I am out of town occasionally and I'm looking for a fool proof solution that my wife can do in the middle of the night when it's 2 degrees outside.widmn said:Doesn't the transfer switch just "idiot proof" what could really be a simple solution?
That being:
1. Turn the power off at the main breaker entering the house. Plug the generator in and turn it on.
2. Here's the key... After the emergency outage, Remember to turn the generator off and disconnect it BEFORE turning the main switch back on.
Forgetting to do step 2 could blow everything in your house and electrocute someone.
Ford850 said:That sums it up. It's all about risk. How much insurance do you have in case you electrocute a lineman? In my case, I am out of town occasionally and I'm looking for a fool proof solution that my wife can do in the middle of the night when it's 2 degrees outside.
That being:
DetroitTom said:I've been doing some research on adding a transfer switch to my house and thought I'd post this in case it has not been posted before.
I found the most economical solution is a transfer switch sold as a Gen Tran or Pro Tran (by Reliance). The prices are lower on the Gen Tran site. In order to wire this switch in, you don't need to disconnect power from the meter, you wire it in like you are adding another circuit. For a 5000 watt generator the whole deal is $150 including shipping. The cord to the generator is extra.
Here is the Gen Tran site:
Gentran Corporation: Generator Transfer switches for home & business
Reliance site with installation video and installation manual links:
http://www.reliancecontrols.com/ProductDetail.aspx?20216A
I'm sure this isn't for everyone, but I think it is a pretty economical solution, considering that stamped sheet metal circuit breaker interlocks are the same price (below).
RobS said:That Gentran 30A 10 circuit model looks exactly like the unit I installed. Mine came from Home Depot, EmerGen brand I think. Tom, are you sure you can wire this in without disconnecting the power? Or are you only talking about bringing the genny online once the power goes out? To install mine, I certainly had to disconnect the power.
RonMar said:That is the cheapest price I have seen for the Gentran panels. Both methods work, but the interlock is easier to install(less wire shuffeling) and more versatile IMO. The Gentran panels you linked to limit you to applying power to just those 6 circuits wired thru the add-on panel, while the interlock setup allows you to power anything on your house panel within the limits of your generator. The interlock does take a little more operator skill as you need to shut off loads that the generator may not be able to handle. Some colored stickers on the panel face beside the breakers that must be shut off make this a simple affair even when using a flashlight to get the backup power on line.
