Generator to power welder
   / Generator to power welder #11
I'm actually talking about a brand name.. I buy some called ez-strike for my 'baby' 1/16 and 5/64 rod 70a welder... I'd swear that I could strike an arc on a piece of wet cardboard with them. Perhaps they make them in 1/8 as well.. or at least 3/32??
Soundguy
I wanted to provide the results of my experiment powering my AC/DC welder with a 4000 watt generator. It works!
I was able to weld 1/8" clips and weld plates/splices to c-purlin with no problem. I know it won't weld really thick stuff, but it did do fine with this. I even sectioned a couple of welds to make sure I was getting complete penetration. I was tickled pink!
Welded at up to 70 amps DC with no problem using 3/32" 6011. Also used some 1/8" 6011 but it did require a bit more amperage. I think I could have gone as high as 90 amps without bogging the generator down. At 70, it definitely had a load on it, but nothing serious. Certainly not as much as the load I usually put on it, electrofishing ponds for my lake management business.
As a result, the framework of my rv/boat barn is complete and ready for painting and sheet metal.
Thanks to everyone for all the feedback.
   / Generator to power welder #13
Good job! I love proving the naysayers wrong on this one. Even the Lincoln website claims you need some monster generator to power their welders. It may be so that they can sell more welder/generator combo units.
My new house has no 220v plug tied to the grid so all of my fix it jobs are done with the generator. Honestly I would rather weld on grid power due to silence and the lack of a surge when striking the arc on a genset but sometimes you just need the mobility.
Glad it worked for you.
   / Generator to power welder #14
No stove plug? Dryer outlet?
Soundguy
   / Generator to power welder #15
Soundguy
Good point, I suppose those plugs are there but I would have to rig up an adapter and remove the appliances to gain access. Momma won't be happy.
   / Generator to power welder #16
I'm a little late to this, but my experience is the same as Highbeam. I weld with smaller rod and a lower power setting on my generator and AC/DC arc welder from time to time.
Fishman,
How about starting a thread on your project?
Eddie
Yes it is great to find out something works against all odds.
Hi Eddie. I would love to start a thread on my project, but I just don't have time right now. I don't know how you do it on your end. You've provided so much detailed information on your projects and you do a LOT of them. I, for one, am appreciative.
I hope to post some details in a month or two when things slow down. I do have some pictures at least.
BTW, my welding/generator unit was able to output 90 amps without lugging too much the day before yesterday. It was a no-go with 1/8" 6011, but it welded great with 3/32.
   / Generator to power welder #18
My dryer sets 8" from the wall in the garage.. plenty o' room to unplug it and plug the welder in.. I just make sure I am not using more amperage than the outlet is rated for. That's pretty easy since I havn't had to weld at over the 120a setting yet.
Soundguy
   / Generator to power welder #19
I could and did weld all the way up the 225 amp setting on AC mode which takes less input power than DC mode but the arc wasn't as powerful as when using the grid power. Maybe the generator was putting out lower voltage. It sure would bark when I struck that arc.
We freeze too much to have our wash machines/dryers in the garage, I've always had them in the living space of our homes.
Just Friday I had to pull out the washer since I discovered by sound a dripping hose. Argh! The cabinets are built around the units so it is out of sight.
   / Generator to power welder #20
I was about to start a thread on using my Lincoln 225 AC 'Tombstone' welder on a 4 KW generator when I saw this one already open. Kinda wish I'd have read all this good info before my own 'field trials', it would have saved me a lot of guess work. Coincidently, I have that same Generac 4000 watt generator and at first tried welding using 1/8" 6011 rod, man that was an absolute no-go as that sized rod at > 100 amps shut the generator right down. I had some stock gates that needed to be modified right away, so I went to Home Depot and rented a little 110v Lincoln wirefeed machine which worked fine on the generator, but marginally got the job done.
I still wanted to be able to use my stick welder for future jobs, so I started a little experimenting. First I bought some 1/16" rod and dialed the old AC Lincoln down to 40 amps. Presto! a nice arc and near perfect looking beads, but only good for really thin metal and those 1/16" rods burned up very fast. I figured the 'sweet spot' would be 3/32" so that was my next move, and it worked very well.
Bottom line for me was 3/32" 6013 rods at 75 amps for welding 1/8" stock. Actually pretty good looking welds and not overworking the generator, I was able to weld for prolonged periods of time. As others have stated, its a little tricky starting an arc using this small generator, but I found myself getting used that with practice, so its not a real problem. I like my stick welder, and this combination allows me to be mobile around the ranch, albeit somewhat limited on welding heavy stock.
5' MOWER (A52706)
5' MOWER (A52706)
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2019 Grove TMS500-2 40 Ton Hydraulic Truck Crane (A60460)
2019 Grove...
2003 Big Tex 10PI...
2014 Ford F-350 4x4 Ext. Cab Palfinger PSC4216 2 Ton Crane Service Truck (A60460)
2014 Ford F-350...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
