Generator Attachment for PT-1430
/ Generator Attachment for PT-1430 #21
You could have a leaky check valve in the pump. Has anyone tried adding a check valve before the tank. You could also have low in your tank or a bad bladder in the tank. You really need to fix this soon nice you will wear out your pumpkin cycling it too often.
/ Generator Attachment for PT-1430 #22
Both tank and pump are less than one year old... The originals lasted 26 years, so I guess I can't complain.
But, you have a point. That experience was with the old setup. I've only had to run the generator about 45 minutes since the new pump/tank were installed, so I haven't had a lot of experience trying to load balance with it. I also increased the size of the pump but went back with the same size tank.
