Generally slow response to page loads
/ Generally slow response to page loads #21
Though not really a long one, it is a little longer then normal.
/ Generally slow response to page loads #22
/ Generally slow response to page loads #23
This is without question the slowest site I visit...I'm on dial-up at home and often times its just way too painful to sit thru, so I usually visit here while I'm at work /forums/images/graemlins/wink.gif
/ Generally slow response to page loads #24
/ Generally slow response to page loads #25
Yeah same here for me. I cna't even psot comments. It takes so long for the post to go through most of the time I jsut end up closing hte browser.
i jsut tried to add a 50k photo, now that is real small and after 15 minutes of it jsut crawing to accept the photo I quit. I did it twice. Just generally the forums have been slow to load and almost impossible to post. I hope this information helps you.
Even if you send a private PM it crawls to the point where I don't send them to much. Seems like it has been this way for a couple weeks now but it takes a while before you become so frustrated that you actually stop and take the time to notify management. If it matters any I ususally un check the box that says I want to preview my post.
/ Generally slow response to page loads #26
/ Generally slow response to page loads #29
oh heck I might as well add this one. I have never gotten the see all discussions in the last 24 hours to work. he page never loads. I can get 12 hours to work but that is it. Anything over 12 hours the page does not load. Correciton on my timing, that was 4 1/2 minutes for that first psot of mine to go through. I have DSL and do not have slow response anywhere else, jsut on this website.
/ Generally slow response to page loads #30
/ Generally slow response to page loads #31
This morning, after I checked the weather report and a couple of newspapers on the Internet, I tried to go to Countrybynet, waited a couple of minutes, and when it didn't come up, I tried Tractorbynet with the same results. So I closed the browser without ever getting to either one, and went on to do some mowing and other things. When I came back later in the day, it was working fine. However, a couple of days ago, I had the same thing happen except I wasn't going to do something else, so I waited and when pages loaded, they showed to have been generated in fractions of a second, so I suspect the problem then, and possibly today, was somewhere in the routing and not TBN's server. /forums/images/graemlins/confused.gif
/ Generally slow response to page loads #32
/ Generally slow response to page loads #33
I posted 5 pictures, around 80K each, last night from home. I am on 28.8 dial-up. Each picture took about 30 seconds to upload. I then viewed them to make sure they were correct. They took about 25 seconds to load. Seems fine for dial-up to me. /forums/images/graemlins/crazy.gif
/ Generally slow response to page loads #34
/ Generally slow response to page loads #35
It depends on what time of the late night you want to use TBN. It's very slow every night in the wee hours. Ibrahim had said he has an auto maintenance program of some sort going late night.
John
/ Generally slow response to page loads #36
John
/ Generally slow response to page loads #37
From this morning, 5/28, approx 7:29 EST.
Generated in 45.241 seconds in which 45.222 seconds were spent on a total of 16 queries. Zlib compression enabled
This is usually the time I notice the site bogging down. But it is hit or miss. I will get 2 or 3 pages fast & then one or two slow.
/ Generally slow response to page loads #38
Same with me, generally slow across the board.
Generated in 36.85 seconds in which 36.841 seconds were spent on a total of 16 queries. Zlib compression enabled.
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
1996 Ford F-350 Pickup Truck (A64194)
1996 Ford F-350...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2021 CATERPILLAR 302.7D CR EXCAVATOR (A65053)
2021 CATERPILLAR...
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
HARDEE DITCH BANK MOWER (A64278)
HARDEE DITCH BANK...
