Sickle Bar General questions about Sickle Bars
   / General questions about Sickle Bars #51
a scored shaft will wear out new bearings?...what's "too expensive" ?...can a scored shaft not be re-machined ?
Also...looking at this manual http://i.ebayimg.com/15/!B53h!!wEWk~$(KGrHqV,!hUEyrsppfOHBMvRKoD8v!~~_3.JPG
this does not look like a sickle bar..what is with the wheels etc...?
thanks for all the information
If the crank is scored, it will ruin a new bearing pretty quick. Can't be machined and still fit the standard MF bearing. Lets hope for the best. The mower in the picture is pulling a hay crimper is what I see in the picture. This was a option some of the mowers had. A hitch and also a 540, 6 splined shaft coming off the big pulley at the back of the mower. Ken Sweet
Thanks again for the invaluable information...
for as little as I will be using this (a couple of hours maybe twice a year) I don't mind going through some bearings every so often...it will be several days before I can get a wheel puller and get a look..
I think it will serve my needs...I'm going to start a restoration process...I bought the operators manual from the e-bay source...and I located a MF dealer about 40 miles from me...
   / General questions about Sickle Bars #53
You are welcome and good luck. Ken Sweet
   / General questions about Sickle Bars #54
...there are about 8 residences along this road that is entirely private...landowners actually own the road and pay taxes on it...the only ROW is granted for telephone and power...
Around here, if you had 8 residences on that size road, you could very likely have the county "annex" the road and have it paved, as well as have the county maintain the ROW's. That may not be your wish / the wish of the other homeowners?
Another thing that comes to mind... 8 x $150 = $1200. Perhaps your neighbors would be willing to put some type of agreement together that the equipment would be community property, and that you would (so long as you are able) operate and maintain said equipment for the puprose of clearing this ROW X number of times/year?
   / General questions about Sickle Bars #55
Not much different than what I cut on our road. I used a 5' rotary cutter (Bush Hog) and often used a 7' finish mower on my old 22hp yanmar. Set the mower height up with the gauge wheel spacers for the first cut and set her down for the second pass. The mowers were so much wider than the tractor that you could hang it over the edge a bit. And, you can offset the mower with the draft arm adjustments even more.
My used 5'er was $250 and the finish mower was more (new though). Now I do everything with the finish mower as I set it to max height for the occasional road work. (Gator blades)
the road is 100% private property...the only ROW is allowed for utility lines and we mandate what they do as far as "trimming"... the last thing we want is a paved road...access on this road is by right of egress by the land
owners...
there is only one full time residents...we hare here about 8 months...the rest are "weekend warriors"
as for another type of mower...nothing else would work...to use a pull behind mower the tractor would either need to be in the ditches (impossible) or on much too steep of slope to operate...(side of the mountain)...if you drive off this road on the low side the only thing that keep you from going all the way to the river are the trees...
the only alternative to a sickle bar is hand held string trimmers...
   / General questions about Sickle Bars #57
We have lots of private roads up here. Towns are reluctant to take on new roads and if they do the specs for the road are tough to meet. There is usually a road agreement amoungst the residents like LostInTheWoods said.
Yup...the cost of bringing all the culverts etc. up to county requirements would make it cost prohibitive regardless of our apathy towards doing so...Also, there is no need for any formalized "agreement"...I have been maintaining the road for for 40 years...begining when there were only three residents (home-sites)...(and no culverts)...if there is a real need for a load of gravel or other repair there is never any reluctance for all to chip in and get it done...
The "new comers" get quickly educated...the biggest problem we have is with delivery trucks and occasional construction vehicles but they too are quiclky "informed" on "how to drive"...:D
   / General questions about Sickle Bars #59
This doesn't cover equipment ?
   / General questions about Sickle Bars #60
Ditto.
I understand that you don't need a formal agreement on who maintains the ROW. My thought was simply that if the fix-r-upper equipment doesn't pan out, your neighbors might be willing to share the cost in regards to obtaining something in better condition.
Of course, if all goes well with reconditioning the item you have, then no worries. :thumbsup:
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
Concrete Mixer Mini Skid Steer Attachment (A55851)
Concrete Mixer...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
