General Maintenance question for my tractor..
/ General Maintenance question for my tractor.. #1
platinumaa
i have a 2011, r4041.. for some reason i couldnt find the oil filter that i need.. i did a check online and nothing came up except a package option.. but that still didnt say the oil filter type..
im at my 50 hour check.. can someone please give me the oil filter spec so i can go down to napa, or ace hardware, or possibly even walmart to get my oil filter.. i assume it will have to be cross-referenced
since where at it.. does someone have the info on hydralic oil and fuel filter
i appreciate the help!!
thanks
tony
/ General Maintenance question for my tractor.. #2
There is a thread in the LS forum about filters. You don't like your dealer. I found mine to cost less from the dealer.
/ General Maintenance question for my tractor.. #4
Sorry it wasn't there. I don't have that model someone should come by that knows.
/ General Maintenance question for my tractor.. #5
Look for my post in that filter thread. Yes the filters are the same. I did not list a filter for a hydro model but shuttle and EZ models use the exact same filters
Boomer.. perfect.. thanks...
just to summarize and confirm.. the filters/info for an R4041 is:
1) There are 3 drain plugs for the hydraulic fluid.
2) The manual says it takes 11.4 gallons of hydraulic fluid. I found that it only takes about 10.
3) Oil capacity calls for 1.9 gallons. I found that it only takes about 1.5 with filter.
As for the filters, I used all NAPA brand.
Air: (Inner) NAPA 2985 (Outer) NAPA 6438
Hydro: NAPA 1715
Fuel: NAPA 3128
Oil: NAPA 1064 (has bypass and anti drainback)
/ General Maintenance question for my tractor.. #7
No Prob..
In that post I state "hydro". I should have clarified that to read hydraulic so not to be confused with the "hydro" trans.
