Generac Generator
/ Generac Generator #1
Bob Ha
DFW, TX
NH TN75, Kubota M9960, Kubota M7040, NH T4.85
Looking at purchasing a Generac 7550EXL for $500 with little use. Anyone have any knowledge of the good and bad of this brand. It will be used for multiple tasks such as power outage stand by, pumping water from ponds to water new stand of grass ... thanks
Specs:
Running Watts 7550
Starting Watts 13500
Volts 120/240
Amps 83.3/31.4
Engine Brand Generac
Engine Series GN410
Horsepower 15
OHV Engine Yes
Fuel Tank Capacity 7 Gallon
Run Time @ 1/2 Load 10 Hours
Alternator Brush
Start Type Push Button & Recoil
Low Oil Shutdown Low Pressure
Automatic Idle Control Yes
Muffler Low Tone
Fuel Gauge Yes
Hour Meter No
Dimensions 32" x 26.5" x 29"
Weight 245 Lbs.
/ Generac Generator #2
I've got a Generac PTO generator and it works great.. Generac is an old established generator manufacurer and in my opinion it beats the Chinese for sure and parts and service are readily available and it sounds like a fair deal you are getting.
/ Generac Generator #3
I found some reviews on amazon, and all the generac generators seem to be rated very highly
/ Generac Generator #5
Bob that seems like a good price for the generator. Is there anyway you can run it and put it under a load and see how it performs.
Wayne
/ Generac Generator #6
Wayne
When I bought a used generator, I took a Kill-a-watt meter with me and a bunch of electric heaters. This allowed me to measure the voltage, amperage and frequency output under full load.
/ Generac Generator #7
I've had pretty much the same generator for 6 years now. After runnning during a a few power outages It smoked a surge protector in the house. The surge protector saved the TV and other expensive stuff. I checked generator voltage and it was 174!. There is a regulator. I think it was about $50 and replaced it myself.. Had a friend with same generator and problem. He had no surge protector and lost a few items. I've had no problems since then. Must have been a bad lot of voltage regulators. The thing is pretty good with fuel and voltage is very consistent no matter what the load is.
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
ALUMINUM HEAD ACHE RACK (A63569)
ALUMINUM HEAD ACHE...
6R BEDDER (A63291)
6R BEDDER (A63291)
2011 Case IH Magnum 315 Tractor (A64047)
2011 Case IH...
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
