Generac 15KW generator engine tear down
/ Generac 15KW generator engine tear down
I like the idea of making the 8kw unit portable and use as a backup! One year, before wiring it permanently into my house, I used it in a field for a party powering the lights and the live band. Worked great, but the 100lb bottles really started the sweat after a while, but genny just kept on running all night long (well, until about 4am or some when I, ahem, "checked out" :))
/ Generac 15KW generator engine tear down #42
My friend and his dad get these engines, and then discard everything but the block, crank and bare heads. Then they bore them out and put in larger pistons, valves, valve train, etc and set them up to run 15:1 compression on methanol. They also discard the OEM ignition coils and run dual Bosch blue coils with dial Mopar racing ignition boxes with individual crank triggers for each cylinder. Spin around 9500 rpm.
Yep, those dudes know their Generacs. I think they are actually getting about 120 HP. For the record, they do tractor pulling, not tractor racing. They finished in 2nd place at the Nationals 2 years ago (only time they went). Just to hear this thing run is amazing - it sounds exactly like a small block 350 when they hammer it. Great job Greg and Frank!
Hey Stu. I edited my post to read tractor pulling. :)
In preparation for swapping engines, I went ahead and separated the generator from the engine.
First step was to remove the rear bearing carrier:
And then the stator:
Now I need to go get me a new bolt that matches my current rotor bolt and cut about 3" off the bolt head end, then slot it and screw it into the crankshaft. Then screw a M12x1.75 bolt into the rotor until I brake the taper. I'm sure that will be all kinds of fun.
/ Generac 15KW generator engine tear down #44
Is this standard procedure for removing the rotor from the engine? I don't quite understand.
-Stu
Yep, that's the procedure listed in the service manual. The rotor shaft is hollow and by screwing a long stud into the crank, and then screwing a larger bolt into the internally threaded rotor shaft, it will push against the stud, and force the rotor off the crank taper.
/ Generac 15KW generator engine tear down #46
Can you take a pic of this while you are doing it? Seems like an odd process.
Here's a shot right after I got the rotor shaft separated from the crank. Red arrow on the crank is where I screwed in the stud (also red arrow). I had to sacrifice one of my long Phillips screwdrivers for the task, see here supporting the bolt/shaft pieces. Even after letting the rotor/crankshaft taper soak overnight with PB Blaster, it still took a few blows with a rubber mallet to break it after tightening the bolt (yellow arrow) into the rotor real hard.
Here's the rotor after being removed. Red arrow is where the yellow arrow bolt from above pic was tightened into.
Close up of crank taper:
And some shots of the engine getting ready to be swapped out for a unit with only 12 hours on it. The bottom end on this failed one looks to be in real good shape. Once we pop the crank cover to steal the oil pump and pick up tube, I'll be sure to snap a few more shots to see what the internals look like.
My friend's dad that I'm getting the virtually brand new replacement from wouldn't give it to his son over the weekend. He insist on coming up himself to swap the oil pump to the new engine to ensure everything is done right. I'm quite confident that the replacement engine will be rock solid!
/ Generac 15KW generator engine tear down #48
Cool beans, Peter. There is nothing like having somebody that has done it many times come up to swap out the parts for you. That way you are guaranteed that it will be done correctly. Any idea how soon he can come?
The rotor to crank seperation process makes sense now. The only thing that confuses me still is what is holding the rotor to the crank? I don't see a keyway in the crank so I am wondering how they prevent it from slipping. Is it just a pressure fit?
Yep, just a pressure fit. The taper provides an incredible amount of surface friction, way more than the generator would ever be able to overcome, even at full load. There are no shock loads like, say a gearbox with a clutch could exert. You do have start up loads, like when an A/C compressor turns on, but you have the inertia of that heavy rotor spinning at 3600 rpm to absorb that.
Frank is coming up on August 9/10th to perform the swap.
I split the crank case to see what the bottom end looks like.
Cover:
This image should make it pretty clear who manufactured this engine:
Closeup of rings on #1:
Closeup of rings on #2:
#1 cylinder wall:
#2 cylinder wall:
I'll still proceed with the engine swap, but from what I can tell, the bottom end on this engine is 100% perfect, the issue was all in the heads.
/ Generac 15KW generator engine tear down #51
Does look good.. are you getting the guys 100hp motor.. :)
/ Generac 15KW generator engine tear down #52
Nope. Peter is getting a gently used version of the same motor - not the heavily modifed version that they use for Tractor Pulling. I don't think the generator would last long being spun at over 9K RPM. I have visions of it vibrating off of the pad, grenading, and then copper and steel everywhere. Not to mention that it would probably generate over 400 volts at like 180 HZ and likely blow up most of the stuff connected to it. You would also need a fuel truck parked outside to feed the bad boy tons of methanol.
I'd rather have an engine modified to run at 1800 rpm instead of 3600, use half the fuel, yet be able to deliver the same 32hp and then swap in a 4 pole rotor instead of the current 2 pole rotor so that the generator would still put out 60hz. :)
/ Generac 15KW generator engine tear down #54
It takes power to make power. There is no magic. You are going to burn just about as much fuel even at half the RPM. The only real benefit would be quieter operation and less cycles on the engine. Interesting idea, though. Frank could probably hook you up with a manufacturer for the stroker crank and new rods:cool2:
Nah, at that point it would make sense to just move to a liquid cooled diesel, which is the direction I was leaning until this opportunity for an almost free 15kw air cooled LPG burning unit presented itself.
Like this 25kw Kubota:
Kubota 25,000 Watt Diesel Generator
Look at the fuel curve. This unit burns only 1.9 gal/hr producing 25kw. My LPG powered unit consumes almost 3 gal/hr producing 15kw. Pretty amazing. I do realize diesel has a higher energy content, but still.
But unless I have 10+ full days a year without utility power, a diesel generator would probably not pay for itself in my lifetime if that was the only deciding factor.
/ Generac 15KW generator engine tear down #56
I bought my 10KW Kubota powered gen from them. They do a nice job putting together and wiring the unit. It came filled with oil, and had battery cables and all. I had them add a start/stop controller, which was only $ 200 more. If provides 2 wire start/stop, all of the sensor monitoring, glow plug control, crank limiting, etc. Very nice unit, which is full programmable. They mounted it in an enclosure and mounted it to the generator on shock mounts. All was fully wired up. I do not have (by choice) automatic start, and I have a manual transfer switch arrangement on the breaker panel. I also have a small float charger on the battery, so it is always ready to go.
paul
/ Generac 15KW generator engine tear down #57
I live in Florida and got sick and tired of the portable/semi stand alone generator hassles. Upgraded to a 20Kva Stamford NewAge genset powered by a Kubota V2203 4 cyl diesel. Everything runs through an ANSCO automatic transfer switch which also exercises the unit as I wish. In addition, I installed a Power-Saver 1200 primarily as a whole house line conditioner/surge protector but in the process began saving from 12-18% on my monthly utility bill. Gota love that!
Runs entire house including A/C, elect stove, elect water heater, lights, well pump, computers etc. with not even a burp. Best investment I ever made.
/ Generac 15KW generator engine tear down #58
Ok, what the heck is a Power-Saver 1200 and how does it save you money? Does it just turn stuff off at certain times?
Check it out Stu:
Power-Save Energy Corp.- Save Energy, reduce electric bills, power save, save power, power-save, , low electric bills, lower electric bill, lower, electric, bill, lower heating bill
In a nutshell, it improves the power factor of inductive loads (motors), to .95. So it should be able to make any non EnergyStar rated appliance operate more efficiently. I got a 350w motor that runs 24/7 (primary circulation pump for my salt water tanks), not to mention a butt load of other motors, all in non EnergyStar rated appliances that are more than 3 years old, so I might just have to give this device a try. At $300, it would pay for itself in 5 month it it saved me 15% a month.
It's basically a big capacitor that install by your breaker panel via a 20A breaker, much like how a whole house surge protector would (which this unit also provides).
/ Generac 15KW generator engine tear down #60
Check it out Stu:
Yea but what can it do for metal halides??
