Gehl HL4500 alternator substitute
/ Gehl HL4500 alternator substitute #1
Tony63
1978 gehl hl4500
anyone with info where to get or a car replacement that will work for swapping out the old alternator.
/ Gehl HL4500 alternator substitute #2
Try db electrical on the web I have had great luck with them.
/ Gehl HL4500 alternator substitute #3
Does your 4500 have the Ford 4 cylinder gas engine? If yes I would expect there to be multiple source options since that was a pretty common engine in the 80s.
/ Gehl HL4500 alternator substitute #4
You can get Delco one-wire alternators cheap from many sources and they started at 63 amp if I remember correctly, which is more than enough for tractor use. The alternator on my 40 hp tractor is only 20 amp.
