Gehl 4635 glow plug ?
/ Gehl 4635 glow plug ? #1
ALKY
bedford co. pa
tym 233hst
when I turn my ign ccw to heat plugs indicator light comes on and back off. would that be the relay or something else?:confused:
/ Gehl 4635 glow plug ? #2
Hi ALKY. I don't know what tractor you have, but I and others on this board have experienced glow plug lights that have the same issue. However, a check with a multimeter confirmed for me that as long as I held the ignition switch in the "heat" position the glow plugs were working, even though the dash light flashed on then off.
Hope it helps. Jeff
it always stayed on before.it starts but runs rough for a bit.BTW it is a skidsteer
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A64194)
1987 Fruehauf MC...
BUSH HOG 4R48" ROLLING CULTIVATOR (A64278)
BUSH HOG 4R48"...
2021 Bobcat UV34 4x4 Gas Utility Cart (A64553)
2021 Bobcat UV34...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
