Gearbox grease instead of oil
   / Gearbox grease instead of oil #11
check the fill plug.. some of them have a lil 'cap' on them.. which covers a hole in the plug.. cap will be sheet metal.. whereas plug is a pipe plug.. etc.
soundguy
   / Gearbox grease instead of oil #12
Can't seem to find a vent on the gearbox.
David from jax
If it does not have a vent, I have drilled a 1/8 inch hole in the filler plug and then inserted a cotter key to mostly block foreign material out. If you dont put the new seals in, you will need to drain all the old oil out and try something like "gun grease". It is sorta a jelly consisinity and cant run out. Many disc mowers use that type lube. Ken Sweet
   / Gearbox grease instead of oil #13
sandman2234. On old macherny, that won't hold 90 oil, it's a comon practis to use 120 oil, also called liquid grease. If that come out fix the seals, or what is causing the seals to leak
David-Davies
I changed the output seal last night. After removing the input shaft guard I didn't see any leaking around that seal, but the was a path running from the side to the front which had me fooled.
Still no sign of a vent, and the fill is a pipe plug. No sign of a drilled hole either. David in Jax
   / Gearbox grease instead of oil #15
previous owner might have lost the original and replaced it with a solid plug.
soundguy
I might cross drill the plug at some future point, and then drill a hole from the inside to intersect that cross drilled hole, to keep down the direct flow of dust into the mower gearbox. Adding a cap over that might not be too hard also, but I think I am just going to check to see if it is still leaking next time I need to use the flail mower.
Thanks everyone,
David from jax
   / Gearbox grease instead of oil #17
remember that as the air in that gearbox heats up, pressure goes up.. with no vent.. seals leak or blow out.
soundguy
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2002 International 9200i Truck (A51039)
2002 International...
2015 Isuzu Sewer Jetter Truck (A49461)
2015 Isuzu Sewer...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
2006 Peterbilt 379 T/A Sleep Cab Truck Tractor (A49461)
2006 Peterbilt 379...
