Gearbox grease instead of oil
   / Gearbox grease instead of oil #11
check the fill plug.. some of them have a lil 'cap' on them.. which covers a hole in the plug.. cap will be sheet metal.. whereas plug is a pipe plug.. etc.
soundguy
   / Gearbox grease instead of oil #12
Can't seem to find a vent on the gearbox.
David from jax
If it does not have a vent, I have drilled a 1/8 inch hole in the filler plug and then inserted a cotter key to mostly block foreign material out. If you dont put the new seals in, you will need to drain all the old oil out and try something like "gun grease". It is sorta a jelly consisinity and cant run out. Many disc mowers use that type lube. Ken Sweet
   / Gearbox grease instead of oil #13
sandman2234. On old macherny, that won't hold 90 oil, it's a comon practis to use 120 oil, also called liquid grease. If that come out fix the seals, or what is causing the seals to leak
David-Davies
I changed the output seal last night. After removing the input shaft guard I didn't see any leaking around that seal, but the was a path running from the side to the front which had me fooled.
Still no sign of a vent, and the fill is a pipe plug. No sign of a drilled hole either. David in Jax
   / Gearbox grease instead of oil #15
previous owner might have lost the original and replaced it with a solid plug.
soundguy
I might cross drill the plug at some future point, and then drill a hole from the inside to intersect that cross drilled hole, to keep down the direct flow of dust into the mower gearbox. Adding a cap over that might not be too hard also, but I think I am just going to check to see if it is still leaking next time I need to use the flail mower.
Thanks everyone,
David from jax
   / Gearbox grease instead of oil #17
remember that as the air in that gearbox heats up, pressure goes up.. with no vent.. seals leak or blow out.
soundguy
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
