gear pump question.
/ gear pump question. #1
wedge40
I have a pump with the following specs that I want to mount on my tractor. It'll be ran off the crank shaft on the front of the tractor. What I want to know is if I only run the tractor at 1500 rpm will the gpm be less than 14.6? If so is there a way to calculate what the flow rate would be? I'm guessing it wont be linear.
Wedge
EATON/CESSNA GEAR PUMP
Brand new EATON Model 26000. Replaces Cessna 26300 Series. Hydraulic gear pump. Ideal for replacement on mobile equipment and other hydraulic systems.
SPECIFICATIONS
* 3000 PSI max
* SAE A 2 bolt mount
* Side ports: IN SAE 16, OUT SAE 10
* Shaft 3/4" dia x 1 1/4" w/keyway
* CCW rotation
* 1.87 cu in displ/rev
* 3000 max RPM
* Rated GPM at 2500 PSI:
* 24.1 @ Max RPM
* 14.6 @ 1800 RPM
* Shpg 7 lbs
/ gear pump question. #2
Yes, it will be less than 14.6GPM since that's what it puts out at 1800rpm.
It will be 12.14 GPM.
1 cu/in =.004329004 gallons so 1.87= .008095238 gallons.
1500rpm x .008095238 = 12.142857 GPM
Thanks Rob, I've gotten lazy in my old age.. I should have been able to figure this out myself. Simple math. 231 cu in a gallon.
Hmm Now I think I might have too big a pump.
Wedge
/ gear pump question. #4
Wedge
Hahaha, me too and surprised one of the whippersnappers didn't beat me to it.
Why don't your just run it at 1800rpm if you need that flow?
It might be right in the good torque range of your motor?
Thats the problem, I'm really looking for somewhere between 9 and 12 gpm. I might end up getting a little smaller pump. Right now I'm using the pump off the tractor, which is 5 gpm, and when I get this done I dont want it so fast that as I raise the loader I'm toss dirt into the air as it hits the end of travel. But it will be nice to have the extra umph for additional valves.
Thanks again.
Wedge
/ gear pump question. #6
Oh sorry, I was thinking you needed more flow at lower rpm.
But if you already have the pump, just run it between 1112rpm (9GPM) and 1482rpm (12GPM) then, instead of buying a new one. That would work, right?
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2001 MACK CH613 KILL TRUCK BOBTAIL (A65643)
2001 MACK CH613...
