Gear drive vs hydro
/ Gear drive vs hydro #381
As for comments (from others) about the gear heads being elitist; well how does that work? We're the ones forced into buying primitive (and by all accounts useless and dangerous) tractors with few amenities because we don't have the money for a luxurious HST with heated cup holders and an iPod socket. How is it that we're the snobs?
Reminds me of the long division vs calculator argument. Some learn to do the 'primitive' math.. some punch buttons... both get the (hopefully) correct answer.. some of us just like to plug a bit more ;)
soundguy
/ Gear drive vs hydro #382
Right, but anyone could guess just the opposite and be equally as likely to be correct. The reason that I say this is because reliability is simply an unknown. Valid reasons why you might see fewer repairs on HST would include a fluid based system to buffer shock loads but it might also include the fact that the vast majority of HST machines are weekend warriors, many of them not much bigger than a lawn tractor, that get very few hours per year and those hours likely spent mowing. Virtually any machine that gets limited use will get limited wear and tear.
Also, up until recently, geared CUTS and Uts probably got heavier use and abuse than comparable sized HSTs. With the decline of geared machines, that's probably not as true now and a geared machine like mine probably gets no more use than the average BX estate tractor.
Valid reasons HST might have more repairs would include more complexity. The converse is true for geared.
But here is the thing. If my clutch goes out, I'll fix it myself and there are a fair number of people here at TBN who could do the same. I dare say there are few if any who are going to go tinkering around in the guts of an HST. Plus, I suspect my clutch will last longer than me. But, being a pessimist, and after going on and on about how great gear tractors are and about how I'm the Zen Clutch Master, karma is bound to step in and mine is bound to burn out next weekend and I'll be posting a step by step pictorial about how I replaced it myself.:D
But as has been mentioned, there are virtually millions of aged gear machines with thousands of hours running on the original clutch. No matter how you slice it, that's a proven track record.
We're all ears. I'm sure we think we've heard it all by now but a fresh perspective would be a joy to behold.
I owned a John Deere 2010 High Crop and had to replace a broken piece in the 12 speed tranny, 8th gear if I remember correctly. That was a nightmare and can only hope I never have to get into my HST. Being that geared is not by all means bullet proof, but very effective obviously. HST IMHO has been very well proven over the years. Just look at the many Bobcat or skid steers out there. I have run many of these and can say they get abused daily on a jobsite. They break down, but for what they are put through I can justify some breaks that happen and not necessarily the HST. For the most part they are a very bulletproof design. HST is here to stay for sure and I won't be going back since I bought my first HST and was very sceptical at first. One you own one and work one you really have no idea of what you were missing. But if you are happy with your gears why change? Only reason why I changed was the killer deal I was offered. I had it in my mind to buy the l4400 gear, but things really did work out and my skeptical mind has been definately put at ease.
/ Gear drive vs hydro #383
Darn, I didn't realize these options were available when I got my L4400HST. Being from the Deep South and prefering ice cold beverages, I don't require the heated cup holder but the iPod socket would be great. Do you know if we can get it later as a dealer installed option? :rolleyes:
/ Gear drive vs hydro #384
Well, first of all, try to recognize humor and sarcasm when you see it. Second, the L4400 is one of few basic HSTs available, so it is generally an exception to the rule. I imagine the overwhelming number of HSTs out there are BX's and Grand Ls right?
Plus, my L4400DT does have a cup holder cooler. But for some reason it only works from December through March.
/ Gear drive vs hydro #385
This reminds me of exactly what I said when I ordered the standard transmission in my new 1982 Bronco years ago. I had changed many clutches and rebuilt many standard transmissions in my 50s and 60s Fords I used for drag racing. I was awed the first time I saw the innards of an automatic transmission and refused to even think about learning how to fix them.
My love of standards disappeared when the 4 wheel drive Bronco transmission started growling and I could find no mechanic willing to do repairs on it other than the Ford dealer who wanted twice as much as they charge to rebuild automatic transmissions. They all said "you should have gotten an automatic, everyone knows how to fix them and it is much cheaper".
Today, if your automatic goes out, a half-experienced mechanic can just go to Auto Zone and get a cheap rebuilding kit and get it fixed before the mechanic working on a standard can even get the parts.
Once, today's operators learn the mechanics of HSTs, they will realize that they are far easier to repair than a standard.
For me, since I work alone with no help, I sold my last old tractor because the clutch was bad among other things, and I can not split a tractor alone, so I will have to get the repairs done whether I have HST or standard now, but it is my hope and belief that this will not be for many years.
/ Gear drive vs hydro #386
Sorry, I was trying to be humorous too. Maybe I should have put a few :D :D :D at the end?
/ Gear drive vs hydro #387
It is interesting the range of experiences that people have. I had a 1984 Nissan 4x4 P/U for years. Transmission went bad, bushings or something, lots of metal and brass looking stuff in the fluid. Shade tree mechanic fixed it for less than $300 (including new clutch) in a garage that looked more like a barn and it ran for another 75,000 miles before being totalled in an accident. And that was a Japanese truck, not a Ford. I think your troubles had more to do with that model than manual tranny's.
But to be picky, I don't think the analogy stands anyway. An automatic tranny in a truck or a car has very little, if anything, in common with a tractor HST.
Did I mention that I despise automatic transmissions in trucks too. I bet that surprises...no one.:D
I have the shop manual for my 4400 and to me, it looks quite complex. But in reality, if you read it, its just a very basic, simple, easy to service geared tranny. The PTO (hydraulic clutch) looks a little tricky, but anything else in there should be serviceable by any competent tractor mechanic, and fortunately, I'm related to one. Cracking a tractor is no big deal in his shop.
I also think it is funny that the HST crowd has this idea that anyone who spends time on one will give up their geared machine and never go back. There are two flaws in this idea: 1) Not everyone can afford an HST and 2) Some people need what their geared tractor provides even if they did like the HST.
We've gone through examples of both of these ad nauseum. People who use and like geared tractors are not Luddites, which seems to be a popular but flawed notion. We're simply people who have chosen the best tool that we can afford for the jobs we have/want/need to do. Its just that simple.
/ Gear drive vs hydro #389
[You could get a N ford tractor sans starter.. yet still have battery ignition, rubber tires, generator voltage regulator and battery. The same trans bellhousing was used, and a blank plate was installed in the opening. AND you can hit many suppliers and get a starter for less than 100$.. so there... there's an example.../QUOTE]
But gee whilickers, what would it have cost to do the original manufacturing without making compromises for an amenity like a starter. A magneto would have worked well in place of the generator, battery and all the associated foofaraw too would it not?:p
/ Gear drive vs hydro #390
Why are we talking about starters? Who wants a tractor without a starter?
/ Gear drive vs hydro #391
Did you realize that there was a time and there were places where batteries were just not that reliable, electric power may not have been available, the thermometer may have been around -20F or so and the critters were hungry and wanted some ground grain.:D
So, after the battery died it was crank or hitch up Dobbin to give a tug!:D
:DNo chance of hooking up a battery charger either.:D
Oh, and a fellow soon learned not put his thumb over the crank handle too!:D
/ Gear drive vs hydro #392
What does that have to do with the price of cow manure in Milwaukee?
/ Gear drive vs hydro #393
For myself only it comes down to this high-lighted above. I'm not asking for anyone to change their mind, just asking that the point of why I like the HST is taken as I can see why the geared is chosen and can accept that. I can think of many cases where I would buy a geared and would be happy (above 75hp), but I'm not in that scenario. Anyone who demands that Geared is better than HST or vice -versa is missing the point totally as it is an opinion that could be proven either way due to the fact of what the individual requires from it. With the tractor I own I prefer the HST. With that said Geared tractors are far from being junk or not capable. Just like the Ford, Chevy, Dodge or whatever debate....with that said it will be debated forever with no clear winner. I still own a Ford 860 that still runs well and my father has a couple of Massey Harris tractors. All HST is IMHO is time moving on and "old school" will always work as has been proven time and time again.
/ Gear drive vs hydro #395
If you going to be in a hay field all day, i would not want to keep my foot on the hst pedal the hole time. now if the hst had a hand lever that stayed in position like my john deer 316 hst that would be better.
For loader work you need at least the shuttle shift if not hst and for mowing the lawn hst is better even better with the hand lever.
/ Gear drive vs hydro #396
1. Price
2. Reliability
3. Amount of HP loss with HST
4. Ease and speed of use
I get to Part 3 of my opinion on the difference between Gear drive vs hydro and I must clarify that most of my opinions are formed around tractors in the below 50 hp category that the majority of people on this forum have and not the large single purpose tractors that may run all day without even a change in gears or speed.
Some have said that a 45 hp tractor will lose 5 pto hp with HST. First , I do not believe that the power loss is near that significant and it also depends on what implement you are using. If I am sitting still using a post hole digger on my tractor, I can not believe that just because I have HST that I have 5 hp less available to my phd.
I wonder how many of us even ever uses the full hp of our tractors. I know that I have never used my full hp yet. The closest that I ever come is when I am bushogging with my 6' cutter and I always run a couple hundred rpm less than needed for 540 rpm and I never bog down and get a great cut on my grass. When I am pulling my 7' disc, I spin my wheels in 4 wheel drive before I bog the motor down so extra hp wouldn't help me there. I guess what I am saying is that if I had a loss of a couple of hp I probably couldn't tell or wouldn't miss it anyway.
For anyone who has an L4400 gear drive, I wonder what function you can perform that I can not perform with my L4400HST?
Please observe that I am not saying that hydro is better than gear or vice versa. I am just adding my opinions to the discussion on the differences, or lack of, between gear vs hydro.
/ Gear drive vs hydro #398
Yep.. big ditto's.. big difference in variable displacement system and a torque converter system.
When i see people making the auto tranny comparison.. it lets you know what they don't know..
soundguy
/ Gear drive vs hydro #399
Sure.. ford could have made the tractor to not be able to accept electrics.. but why deny themselves al that extra money in the long run.
Way cheaper to make a single set of castings that does double duty.. dressed up or down..
same with lots of consumer electronics that have a hi end model and an economy model.. many time shte electrics and mechanics ar ethe same.. and it's been intentionally 'programmed' down due to what the rom says..
lots of electronics co's have done that for decades...
soundguy
