Gear box maintance
/ Gear box maintance #1
muddpuppy01
Groveland, Fl
LS XG 3032
I have a recently purchased used woods rd7200 finish mower. I checked the oil level and found that is mixed with water. I am going to pull and replace the horizontal and vertical seals. My question is what would be the best way to flush out the gear box? Drain, fill, run, and repeat until it is clean again or is there another way?
/ Gear box maintance #2
Since you are going to pull the seals I would drain, pull the seals, spray in WD40 to displace the water. Then reassemble, fill run a few minutes then change the oil again. This should get the water out and the remaining WD40.
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
HOMEADE 101" X 25' TRI-AXLE FIVE SAFETY HOUSE (A63276)
HOMEADE 101" X 25'...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2015 John Deere CX15 (A64126)
2015 John Deere...
