Mowing GCD600T Grass Collector
   / GCD600T Grass Collector #1
Mavericksane
Taunton, UK
Kubota B2530HDB
Hi - I'm a novice owner of a (lightly used) Kubota B2530 which came with a GCD600T grass collector attached to its side-discharge mowing deck. I'm having problems getting the collector off the three-point hitch - the hitch doesn't appear to drop far enough to let the collector rest on its stands. What am I doing wrong?
Cheers, Mark
   / GCD600T Grass Collector #2
Hi - I'm a novice owner of a (lightly used) Kubota B2530 which came with a GCD600T grass collector attached to its side-discharge mowing deck. I'm having problems getting the collector off the three-point hitch - the hitch doesn't appear to drop far enough to let the collector rest on its stands. What am I doing wrong? Cheers, Mark
Does your model have a mowing deck hight adjustment? If so maybe try setting that all the way down to zero and the hitch should go farther down. On the BX series it's a knob on the left side below the seat.
Good luck!
Sent from my iPad using TractorByNet
Good luck!
Hi Bob
Thanks for your reply. I eventually figured out that the hitch was being prevented from dropping all the way by some "safety" chains which attached between the grass collector and the tractor. Once I removed those (they were slack when the hitch was fully raised), I was able to drop the hitch further and - eventually - disconnect the hitch. My next challenge is disconnecting the PTO from the tractor!
Cheers, Mark
2019 Chevrolet Cruze LS (A50324)
2019 Chevrolet...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2008 CATERPILLAR 573 FELLER BUNCHER (A51242)
2008 CATERPILLAR...
MAHINDRA 5545 TRACTOR (A51243)
MAHINDRA 5545...
2015 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
