GC2310 TLB vs bx23 new guy need help
   / GC2310 TLB vs bx23 new guy need help #31
I understand and agree that is a better arrangement. I assume that both are standard cat 1 size so my implements would fit his tractor?
   / GC2310 TLB vs bx23 new guy need help #32
</font><font color="blue" class="small">( I understand and agree that is a better arrangement. I assume that both are standard cat 1 size so my implements would fit his tractor? )</font>
The BX uses a smaller than standard Cat 1 hitch. Many owner find they must reverse the pins on their implements (not possible on some implements) or otherwise modify their implements to make a standard Cat 1 implement work. Some implements simply won't work with the BX. Henro (aka Bill) modified his BX's lower arms in such a way that he can use most implements without too much grief. The BX is really a great little tractor, well refined and capable, but it has a real weak point and that is the sub-standard size of the Cat 1 hitch.
If for no other reason than the hitch, I think many people who don't need or want a backhoe on a sub-cut will be looking at the JD2210 and the New Holland TZ18 and TZ24 models.
   / GC2310 TLB vs bx23 new guy need help #33
Thanks Bob. Do you (or anyone else) know if the GC or the TZ have a more standard sized cat 1 hitch that doesn't require these modifications or have these limitations?
   / GC2310 TLB vs bx23 new guy need help #34
It is my observation that the TZ is a standard Cat 1, it is my understanding that the GC is a standard Cat 1. But maybe a dealer could jump in and add some more insight?
   / GC2310 TLB vs bx23 new guy need help #35
Doug, I live in NE Ohio and am looking at 2310...what dealer did you buy from? Also, since they do not offer bar tires, did you get the turf or ag tires
Thanks Tompet
   / GC2310 TLB vs bx23 new guy need help #36
((Doug, I live in NE Ohio and am looking at 2310...what dealer did you buy from? Also, since they do not offer bar tires, did you get the turf or ag tires
Thanks Tompet ))
I bought mine from Whites in Atwater..
I got the truffs with mine and some times I DO NOT like them as when U get mud in or on the tread the tires are like Slicks..
I now have 120 hours on it and only prblm so far is the hst slow creep and a small adjustment fixed it.. /forums/images/graemlins/smirk.gif
Having fun moving dirt ...
Doug
   / GC2310 TLB vs bx23 new guy need help #37
Doug, I was at White's a few weeks ago...got quite a bit higher price than (+$2,200 for same set-up) what you listed. I curious if you bought in 04 or was it earlier? Thanks
   / GC2310 TLB vs bx23 new guy need help #38
Started talking to the owner in 2003 and bought in Feb 2004..
Doug
1995 Polaris 300 Explorer ATV (A59814)
1995 Polaris 300...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2017 FREIGHTLINER...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
CAT930K (A58214)
CAT930K (A58214)
