GC2310 Tachometer Installation
/ GC2310 Tachometer Installation #1
PA28150
Hello to all --
I've noticed some discussion on the forum here about the older model GC's not having a tachometer. That issue is probably the only one I have with my machine (2004 model) -- I really do like it a lot! But it seems silly for the operating manual to specify a certain RPM, and then have no way to determine whether you're at that RPM or not.
I asked my local dealer about adding one using MF components (I like the idea of using stock parts). The cost would be around $300. Bad enough to be sure, but what really made me decide against it was knowing I'd have to remove one of the engine covers and replace it with an updated version that would accomodate the tach drive.
The dealer recommended I check out a local auto electric parts supplier in the area. This I did, and was able to come up with a tachometer installation that I think is just as good as the new factory version -- all without having to open up the engine. Cost was just over $200, and resulted in a very smart looking dash (if I do say so myself).
The job wasn't all that bad. If anyone would be interested in details, let me know, and I'll post more pictures.
Rich
/ GC2310 Tachometer Installation #2
Yes, I would be interested in knowing whose kit it is and where I can get one.
I used a tachometer from ISSPRO -- their R8501 indicator, with R8906 sensor kit. I'd recommend this system to anyone considering the addition of a tachometer, because it uses a pair of small magnets to sense the rotational speed. You won't have to do any calibration (as you would if you were to tap the alternator). Just mount the magnets on the engine flywheel and you'll be able to measure RPM directly.
I don't know how widely available the kits are. I was able to purchase mine at a local supplier (Vineland, New Jersey) that deals quite a bit with tractors, as well as cars. I'm sure an internet search will be able to locate some ISSPRO dealers.
Hope this all helps!
archerynut said:
good looking install, job well done!!
Thank you! Feedback from my esteemed colleagues is most welcome (especially positive feedback!).
Underside of the dash, with the tachometer
One of the magnets, mounted on the engine flywheel
Sensor location at front of tractor
Underside of the dash, with the new wiring completed
/ GC2310 Tachometer Installation #10
You guys should check out the Tiny-Tach, at $65.00 it's the best deal for small engines.
/ GC2310 Tachometer Installation #11
Thanks PA28150, maybe I should change my name to C172N?
/ GC2310 Tachometer Installation #12
From a previous post on the subject....
I found another Tach which didn't specify the need for calibration.
Summit Racing - High Performance Car and Truck Parts | 800-230-3030 - Part# ATM-3788 $129.95
Although I haven't measured the diameter of the fuel gauge, it should fit in the panel without much modification.
Does anyone know who sells the lights for the gauges? It would be nice to see the fuel level when working in the dark
/ GC2310 Tachometer Installation #13
I could not find the lights when I was looking, so I bought a cheap set of gauges from Wally Mart and used those lights. I also put a light in one of the blank holes in the dash for the glow plugs.
/ GC2310 Tachometer Installation #14
PA28150 said:
Hello to all --
Rich
Nice job on the install. Are you going to mark (tape on glass) the approximate 540rpm location, or just eyeballit and call it close enough?
/ GC2310 Tachometer Installation #15
The .pdf instruction manual at Summit's website for this tach provides instructions as to how to calibrate.
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
Rolling Cart (A65640)
