GC2300 Loader Control Valve Replacement
/ GC2300 Loader Control Valve Replacement #1
CD25
Massey Ferguson GC2300
Does anybody know of a replacement control valve for a 2003 GC2300 with loader? Mine has a crack in the control valve body and the dealer is telling me to replace it, it will cost $1,000.
Thanks for your help!
/ GC2300 Loader Control Valve Replacement #2
I believe the the valves are Nimco and they are stacked and you could replace just the bad valve and not the complete controller. Make sure you have a crack and not just a bad O ring. The O rings are easy to replace and the ones that came with mine where junk and changed with a better rubber. If it is cracked you might look at this one
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
Doug
Unfortunately it is cracked and not just the O-rings. I have been trying to do some research on the Brand Hydraulics valve you suggested for the last couple of days and I think it will work. I just have not idea on Power Beyond.
I am hoping to get some verification from somebody who has made the switch.
Thanks!
/ GC2300 Loader Control Valve Replacement #4
It shows a power beyond kit in the upper right corner and in the instructions for it use. The drawings show mounting locations. Also I was wrong on the stacked blocks it looks like it is a mono block.
Doug
/ GC2300 Loader Control Valve Replacement #5
From what I can find it looks like you will have to drill new mounting holes on the mount plate and adapt from SAE 6 to SAE 8 on the new valve.
Doug
/ GC2300 Loader Control Valve Replacement #6
Hi Doug, Can you tell me where I can find the O-Rings (part numbers) and are there any step by step instruction for replacing them.
Mine has been leaking for quite some time and I really need to get it fixed. I dread the dealer repair cost on anything.
If you pull off the rubber boot, there are 4 cylindrical plungers that the joystick controls (they go in and out of the block as the joystick is moved. Fluid is leaking out around one of these plungers.
Many thanks for the help.
/ GC2300 Loader Control Valve Replacement #7
AGCO Parts on line is where you can get the part numbers. It shows how the parts go together. Just sign in as a guest.
/ GC2300 Loader Control Valve Replacement #8
I got the O rings from my MF dealer (Blucks in West Lafayette Ohio ask for Becky) and was told by her the OEM white O rings are a waste of time replacing and they fell apart when removed, she sold me a different O rings. I do not know the part #. It took less then a hour to replace the O rings. Remove the front and back of the block and and keep every thing clean and it will fix the problem. Now I have to fix the steering leak, from what I have looked at it will be a lot more work. Winter project.
Doug
/ GC2300 Loader Control Valve Replacement #9
Anyone have a how-to replace the O-Rings for Dummies with pictures?
For example, I assume something has to be done first to relieve hydraulic pressure so fluid doesn't go squirting everywhere when I start removing screws...
/ GC2300 Loader Control Valve Replacement #10
Don't replace the O rings with the tractor running and you have to remove the Quick Releases to get the cover off. There is no pressure in the block at that point. It is a easy repair just keep thing clean.
Doug
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2025 SZYMJ Hydraulic Stump Grinder Skid Steer Attachment (A64553)
2025 SZYMJ...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
