GC2300 60amp fuse
   / GC2300 60amp fuse #1
pdorman
tl100a
I have a 2004 massey GC2300 tractor and the fuse from the alternator has blown out stoppped charging the battery,the massey dealer said it should be a 40 amp not a 60 amp that is in there? it has a F416 on the side any one know anything about this, thanks
   / GC2300 60amp fuse #2
I just checked the one on my lot and it is a 40amp.
   / GC2300 60amp fuse #3
On my 2300, it depends...
The "main" fuse is a 40-amp slow-blow, but the one that's actually on the alternator is a 60-amp slow-blow. The 40A is in a small box hanging below the fuse box; the 60A alternator fuse ( also in a small box) is wrapped up in the wiring harness below the alternator.
My 2310 is an '07, yours could be different....
Photo from maual.
   / GC2300 60amp fuse #4
Photo from maual.
I cannot find mine and am having the same problem on a GC1705 2018 model. ANyone know where exactly it is located?? Thanks
   / GC2300 60amp fuse #5
The GC1705/10/15/20 series tractor does not have a 60 amp slow blow fuse, only fuse between alternator and 12 volt (battery terminal on starter solenoid) is a 40 amp slow blow and and runs from the "B" terminal on alternator through fuse #11 on fuse block (#29 in diagram) and to 12 Volt battery terminal on starter solenoid...... YOu should have 12volts standing all the time on "B" terminal of alternator if path is good...
   / GC2300 60amp fuse #6
Found my problem it was the 40 amp fuse and you were correct no 60 as I tore wiring apart and nothing
Toro Groundsmaster 4000D (A56857)
Toro Groundsmaster...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
MASSAGE CHAIR (A58214)
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
