GC2300 60amp fuse
   / GC2300 60amp fuse #1
pdorman
tl100a
I have a 2004 massey GC2300 tractor and the fuse from the alternator has blown out stoppped charging the battery,the massey dealer said it should be a 40 amp not a 60 amp that is in there? it has a F416 on the side any one know anything about this, thanks
   / GC2300 60amp fuse #2
I just checked the one on my lot and it is a 40amp.
   / GC2300 60amp fuse #3
On my 2300, it depends...
The "main" fuse is a 40-amp slow-blow, but the one that's actually on the alternator is a 60-amp slow-blow. The 40A is in a small box hanging below the fuse box; the 60A alternator fuse ( also in a small box) is wrapped up in the wiring harness below the alternator.
My 2310 is an '07, yours could be different....
Photo from maual.
   / GC2300 60amp fuse #4
Photo from maual.
I cannot find mine and am having the same problem on a GC1705 2018 model. ANyone know where exactly it is located?? Thanks
   / GC2300 60amp fuse #5
The GC1705/10/15/20 series tractor does not have a 60 amp slow blow fuse, only fuse between alternator and 12 volt (battery terminal on starter solenoid) is a 40 amp slow blow and and runs from the "B" terminal on alternator through fuse #11 on fuse block (#29 in diagram) and to 12 Volt battery terminal on starter solenoid...... YOu should have 12volts standing all the time on "B" terminal of alternator if path is good...
   / GC2300 60amp fuse #6
Found my problem it was the 40 amp fuse and you were correct no 60 as I tore wiring apart and nothing
EZ loader trailer (A56859)
EZ loader trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
INBOARD DRIVE (A58374)
HYD BREAKER FOR MINI EXCAVATOR (A58374)
HYD BREAKER FOR...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
Heavy Duty Excavator Ripper (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty...
