GC1723EB Rpm's
   / GC1723EB Rpm's #1
daman1
Bad Axe,MI
Massey Ferguson GC1723E TLB
Not complaining but I noticed the RPMs on my new 23 is around 1850 to 2900 I thought the 23's are governor at 2600?
I'm probably closer to 25 horsepower with this one then.
What's everybody else seeing with their 1723??
   / GC1723EB Rpm's #2
Yep, I'm not sure they all do it, but my 1723 revs to just under 3000 rpm
   / GC1723EB Rpm's
Yup same here, I am thinking about lowering my idle RPMs it idles a good 1500!! I'd like to get it down to around maybe 9 to 950
   / GC1723EB Rpm's #4
I would consult with a diesel mechanic before reducing idle RPM below 1000. Oil pressure may suffer at low RPM when hot. There are other considerations as well for these small displacement diesel engines. For example, my motorhome diesel generator never sees RPM below 1800. It is powered by a 3 cylinder Kubota motor.
   / GC1723EB Rpm's
Being a brand new tractor I would hope oil pressure is adequate on it, lowing the idle by 400 RPMs I can't see affecting it that much.
   / GC1723EB Rpm's #7
My 1723 is about the same. I was thinking the tachometer could be off. I haven't tested it yet though.
The sweet spot for power is at about 2500-2600 rpm on my tach. Anything above that is more power but seems to have little gains.
2016 John Deere Z915B (A50121)
2016 John Deere...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
EZ-GO Freedom RXL (A50121)
EZ-GO Freedom RXL...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
