GC1705 Fuel & Temp Gage Issue
/ GC1705 Fuel & Temp Gage Issue
Think I have figured out what the issue is.
First, the manual is wrong. The description (image) of the fuses do not match the wiring diagram. Go figure.
So, there is a feed (green wire) off the fuse that keeps blowing. The right side running and turn signal rear work fine. When I disconnect the connection that feeds the left running and turn, fuse is fine. As soon as I hook it up and turn on the ignition, fuse blows.
Isloated that set of wired and ran a continuity check on it. Appears it is damaged but is inside of flex plastic wrap, so will have to take things apart and replace it.
Ordered wire and will replace this week. I think this should fix the issue.
Once again, appreciate the help on this issue!
Yeh, so not being an electrical person really made this a fun experience! Picking up some wiring and will be replacing the damaged connections in the next couple of days.
Love when the documentation is wrong.
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
1999 Wallace Trailers Tri Axle Low Boy Equipment Trailer (A59230)
1999 Wallace...
John Deere Z994R (A60462)
John Deere Z994R...
2007 Heil Heavy Duty Aluminum Tank Trailer (A61306)
2007 Heil Heavy...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
