GC1705 Fuel & Temp Gage Issue
   / GC1705 Fuel & Temp Gage Issue #1
Massey2019
Fox Island WA
Massey GC1705
I have a GC1705 that is a great unit. A couple of months ago, the temp gage would stop and start working. I thought I had it fixed, finding some corrosion on the temp sensor. Worked for a month or so after. In the last week the fuel gage and temp gage stopped working. Find the 10A fuse blown. All other functions on the gage panel work.
If I replace the fuse, turn on the key, immediately blows. Checked connections and wiring for defects and see no issues.
My guess is the gage panel has some sort of a dead short in it, blowing the fuse. I've looked and don't really find that this is an issue.
The fuse is the 3rd one at the bottom of the panel, with white letters.
Not an electrical person, is there anything I can check to confirm there is an issue?
Thanks,
   / GC1705 Fuel & Temp Gage Issue #2
Here is my go-to procedure to find a dead short.
Replace the fuse with a 12 volt seal beam headlight unit. These seal beams will pass about 4-5 amps but no more. This will prevent overheating wires and will not blow out like a fuse. Use a couple jumper wires to splice it bulb into the fuse contacts.
When you get the seal beam wired in and the circuit powered up with the key, your dead short will cause the headlight to glow fairly brightly.
Now go around and wiggle wires or components until the bulb goes very dim or out completely. When the bulb goes out or dim, that is the short.
Really appreciate your response! I will pick up a headlight tomorrow and see if I can find the issue.
Called the dealer and told him what was going on. He said it is probably a corroded connection and the gage clusters going bad is not a problem in his experience. Replacing it would cost a fair bit.
I will post what I find. May help someone in the future.
Thanks
   / GC1705 Fuel & Temp Gage Issue #4
Great idea...bordering on genius, anyway good enough to applaud loudly !
   / GC1705 Fuel & Temp Gage Issue #5
While corrosion is certainly a possibility in the malfunction of gauges, corrosion itself will not blow a fuse. Only an overload of current thru the fuse will blow it.
   / GC1705 Fuel & Temp Gage Issue #6
I don't have a problem with my temperature gauge but the fuel gage acts up frequently. I smack the side of the console with my hand and the gauge works for weeks at a time. This has been going on for more than a few years.
   / GC1705 Fuel & Temp Gage Issue #7
short to ground. bet when it blows headlights also don't work.
look towards your oil pressure sending unit and trace from there, bet small spot (I mean maybe 1/32 inch) touching frame.
   / GC1705 Fuel & Temp Gage Issue #8
probably right...and readily debugged using Ipakiz's idea in post #2.
Have time to work on it tomorrow. Appreciate all the feedback. I’ll post what I find.
Thanks
Well, had time to work on this issue today. Understand, I'm not an electrical guy so you may not be impressed with my troubleshooting skills.
1. Disconnected extra connections and had the tractor back to original. Extras are just aux lights and 12v power at the rear to power a sprayer. All on separate, fused circuits.
2. Checked the fuse block for connections and wiring. All was clean and intact. The fuse that blows is #8 10Amp on the attached image.
3. Removed + & - battery connections. Found some white residue on the positive. Cleaned both and reattached. Thought maybe too much resistance.
4. Checked wiring to the seat safety switch for damage. Switch works fine but appears to be on this circuit, so I looked at it.
5. Put in new fuse, turned the key to on, fuse immediately blown.
6. With my marginal schematic reading skills, it appears this circuit also has the left turn light and left running light on it. Checked bulb, it was fine. No corrosion, wiring looked good.
Circuit also appears to have seat safety switch on it. And then to the multi switch and ignition.
7. What has me scratching my head is, with the fuse blown, both fuel and temp gages now work. Left turn signal and running light don't. The only wire that this fuse sees is a solid green one.
Everything else works just like always. I guess if I never have to turn left, all would be fine.
But, would appreciate suggestions that could aim me in another direction.
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2015 Ford F-550 XL (A50120)
2015 Ford F-550 XL...
John Deere M Tractor (NOT RUNNING) (A50774)
John Deere M...
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
2020 NPK GH-7 Excavator Hammer (A50774)
2020 NPK GH-7...
