Gauge wheels
/ Gauge wheels #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I am planning on making some gauge wheels using receiver hitch tube and some trailer jacks. I was looking at this - receiver tube from HF . With this can I use 2" square tube to slide inside? What gauge square tube should I use?
/ Gauge wheels #2
Check these guys out! You've got one in Rah-cha-cha! I use the one in Bflo. Great guys, and I think they're reasonable, for getting new steel that's exactly what you want! ~Scotty
Metal Supermarkets
/ Gauge wheels #3
10 or 12 should work in inches 1/8 to 3/16.Just happen to be building me a set for my rake. Same as yours except i made my tube because using 1-1/2 sq. tube could not find apiece of 2" tight enough fit.Good luck with your project.Framer
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
LOOK! (A65640)
LOOK! (A65640)
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2016 KENWORTH T680...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
