Gator Blades
/ Gator Blades #1
timkins
Fishers, NY
Cub Cadet Model 2542
Got a yr old 2542 and was wondering about replacing the stock blades with Gator Blades. Will I notice a difference? I talked to the dealer last month and he said that Cub had blades very similar to the Gator's. Any opinions?
/ Gator Blades #2
one might queestion that dealer's reply/motive... but - from all the reports I've seen - and having put a set of Gators under a CC deck - results are usually positive.
Much depends on what you want the blades to do. They do a better job of chopping up cut grass clippings and will usually improve your deck's discharging. Overall, they are a longlasting blade unless you are cutting on very sandy soil - the sand will wear the blades fast.... as any blade. They don't seem to improve cutting in a mulching mode with plug much.
Just be careful that you get a true match for your particular deck - Gator doesn't make their type of blades for every single different deck out there... and they also make several blade versions.
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
72in. Land Plane (A65640)
72in. Land Plane...
Ag Leader PF Advantage Monitor (A65640)
Ag Leader PF...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
