Gas Line
/ Gas Line #1
NewToy
Ohio
'05 Farmtrac 270DTC
My father- in -law was telling me of hitting a gas line with a dozer. The dozer got a sniff of that natural gas and it was off to the races. He said that thing was screaming like crazy and he couldn't get it shut off. He finally crossed it into some fresh air and things returned to normal. He said that was quite a ride.
John
/ Gas Line #2
That has happened more than once! /forums/images/graemlins/grin.gif
Most places now require positive air shutoff for diesel engines when operating in an environment that could contain combustible gasses.
Egon
/ Gas Line #3
the only way to shutoff a diesel that has run away like that is by cutting the air flow to the engine, equipment working in areas where gas lines etc are present are often required to have a shutoff slidegate, much like an rv waste valve, in the intake line
/ Gas Line #4
I had a 475 detroit runaway like that had to knock the fuel nozel off with a hammer emergency shutoff came off in my hand. un cool ! /forums/images/graemlins/mad.gif /forums/images/graemlins/ooo.gif
/ Gas Line
I had never heard of anything like that before. Around here it's not uncommon for folks to have their own natural gas well. I wish I had one in the backyard.
John
/ Gas Line #6
One other way, is to discharge a dry chemical fire extinguisher into the intake. It's a last resort as the engine will be trashed after! /forums/images/graemlins/blush.gif
/ Gas Line #7
</font><font color="blue" class="small">( I had a 475 detroit runaway like that had to knock the fuel nozel off with a hammer emergency shutoff came off in my hand. un cool !
)</font>
if the engine was running away from gas in the air, then cutting off the fuel supply by your method would have had no affect on it, the only way to stop it would be to block off the air intake, or as someone else said to shoot a fire extinguisher into the engine, altho i dont see why you would want to do that since it would probably cause engine damage
/ Gas Line #8
When our mechanic rebuilds a diesel, on it's first start he stands ready with a big choke plate if needed.. etc..
Soundguy
/ Gas Line #9
Usually when a diesel "Runs Away" from exlosive vapours in the air it's to late for the engine and operator! /forums/images/graemlins/frown.gif
Egon
/ Gas Line #10
Wouldn't a compression release lever stop a runaway engine? I have one on my Yanmar marine diesel as it is the normal way to stop the engine. If so, why don't more tractors have the simple compression release systems?
/ Gas Line #11
The chances of a compression releif stopping a diesel being fed lots of combustible vapours is pretty slim.
Egon /forums/images/graemlins/grin.gif
/ Gas Line #12
it was not from natural gas it was from the throttle going by the stop and running away but you are right once they get a whiff of gas they are history
/ Gas Line #13
<font color="blue"> Wouldn't a compression release lever stop a runaway engine? I have one on my Yanmar marine diesel as it is the normal way to stop the engine. If so, why don't more tractors have the simple compression release systems?
</font>
You must hate that thing huh? /forums/images/graemlins/confused.gif... Kinda like beating a child to make it stop crying... they both work.. but not the best way to go about acheiving the desired results.... I've never heard of using comp release as the 'usual' way to stop a diesel.. rather fuel stop valves.. etc... All my diesels have printed in the manual that using comp release to kill the engine will... kill the engine... as it washes the cyls down with unburnt fuel.. this reduces lube on cyl walls.. and leads to fuel dilution of crankcase oil.. lowering lube in the whole engine...
Guess yours could be some special case.. but sounds alien to me.. unless for emergency.. etc..
Soundguy
/ Gas Line #14
</font><font color="blue" class="small">( The chances of a compression releif stopping a diesel being fed lots of combustible vapours is pretty slim. )</font>
Why? Even if the fuel simply 'cooks' off from the heat.. with the valves lifted open.. there won't be compression for that compression engine to fire with.. If the fuel-air charge cooke doff.. the path of least ressitance is the open valve.. not the piston???
Soundguy
/ Gas Line #15
I watched mechanics trying to stop a run away diesel when I was in the military. They tried everything, including the compression release. Nothing worked. The engine lunched itself.
/ Gas Line #16
Easiest way is to find out is to try it! /forums/images/graemlins/grin.gif
Get the diesel warmed up, Open up a propane bottle into the the air intake and then pull the compression realease.
Let us know what happened! /forums/images/graemlins/grin.gif
/ Gas Line #17
</font><font color="blue" class="small">( Usually when a diesel "Runs Away" from exlosive vapours in the air it's to late for the engine and operator! )</font>
i have to dissagree, i have seen diesels rev up very high, not totaly run away, but increase rpms very fast, from just a little bit of brake cleaner used nearby, i think that on a concentration that would cause no imediate harm to the operator that the engine would still breath alot in
/ Gas Line #18
Sorry about the lack of proper information.
I was refering to a situation in which there is a lot of combustible vapour; such as in when a natural gas line is hit. In these cases there is often a big bang associated as the vapour cloud explodes. This has happened more than one or two times. Other times a motorized unit may drive into a vapour cloud from a leaking line or ?? Lots of other type senarios.
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2015 John Deere 319DT Skid Steer w/ Bucket (A63688)
2015 John Deere...
