Gas fireplace cleaning
/ Gas fireplace cleaning #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
We have a 10 year old gas fireplace, propane. The front burner has very low blue flames but the back burner has nice natural flame look. This morning, the front burner did not even come on at all. Shut it down and restarted. Small front blue flames returned.
Is this just needing a good cleaning? Would just using an air compressor clear the front burner?
/ Gas fireplace cleaning #2
Three most likly problems in this order.
1 Clogged orifice
2 Cobb/spider web in airway
3 Burner filled with ash IF a log has ever been burned.
The air hose should fix them all.
/ Gas fireplace cleaning #4
Just bought a house with a gas fireplace, trying to get ready for cold weather, what are my cleaning tasks? I went through the venting and cleaned out some pine needles Do I remove the glass front and vacuum out? thanks
/ Gas fireplace cleaning #5
Look online and get a manual for your unit. What the manufacturer wants you to do, can vary year to year. And, it is nice to have the manual.
/ Gas fireplace cleaning #6
That’s what I do with my gas fireplace.
/ Gas fireplace cleaning #10
BEFORE using any type of air compressor - use a good shop vac. That is, unless, you want ash blown all over the house.
/ Gas fireplace cleaning #11
A brass wire brush works well on the burner offices. If they are really bad a Proper Sized Drill Bit may have to be used to clear the office.
All,
I'm back. I cleaned the burners. I removed the two orfaces and cleaned them. Cleaned the piolet as well. I did a test fire with out the logs. Front flame is better but I'd think it should be better.
/ Gas fireplace cleaning #14
All,
front burner is burning as it was designed to burn. It's not designed to burn as much as the rear burner.
The rear is the one designed to give that yellow flame, and burn more gas than the front
2022 EZ-GO ELITE...
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
2014 Ford F-150 Pickup Truck (A61573)
2014 Ford F-150...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
JOHN DEERE 5100M TRACTOR (A63291)
JOHN DEERE 5100M...
