Garden weed control
/ Garden weed control #1
5103Owner
Millville, PA
John Deere 5103
Hey,
attached is a photo of a king kutter cultivator I have been thinking about buying to weed my garden in the spring, will this work well? You can remove the center tines, and leave the outside ones to till in between the rows, and can I add some wheatland sweeps to rip even better? /forums/images/graemlins/confused.gif
/ Garden weed control #2
I believe you'll find there is a space in the middle for straddling the row. There should also be as many a 3 holes in the vicinity of each of the sweeps in that photo, allowing you some adjustment. You may of course replace the sweeps on the tines with anything that will bolt onto them. /forums/images/graemlins/wink.gif
/ Garden weed control #3
I used what appears to be the same cultivator from Tractor Supply Co., but mine was red. /forums/images/graemlins/wink.gif I replaced the points with 6" sweeps, using the "half sweep" on the two in the middle and then straddled the rows.
/ Garden weed control #4
Combination Garden Package
3 Implements to fit one Versitile Tool Bar
/ Garden weed control #5
Where did you get that 3 in 1 attachment. That looks like it may fit my needs also.
little bit too expensive for my needs. $825 compared to $200 is a big difference, /forums/images/graemlins/shocked.gif really neat implement though. /forums/images/graemlins/cool.gif
/ Garden weed control #7
Your right , it really isn't that complicated.
Gleaner Variable Speed Header Drive forS96-97-98 Gleaner Combine (A63117)
Gleaner Variable...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
(2) UNUSED 16.9-24 TIRES ONLY (A64280)
(2) UNUSED 16.9-24...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A64280)
2006 FORD F-450...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
