Garage for Power Trac and Shop
   / Garage for Power Trac and Shop #21
Bob, you ought to ask Ksimolo about his heating systems. Pretty darn cool stuff...
I tried a search on his name and could not find him. What am I doing wrong?
   / Garage for Power Trac and Shop #23
BobRip said:
I kinda like using a good shop vac.... I will probably run some tubing for a central shop vac.
I kind of like using my dust collector. The big 4" hose vacuums up just about anything (including crescent wrenches and screwdrivers if you are not careful).
Think about putting in some 6" PVC runs for dust collector tubing. You said you were into woodworking, so I assume you have a DC or will get one soon (trust me, a vacuum has nothing on a DC to keep a shop clean). I never use my shop vac in my shop, since I have 4" PVC run the length of the shop hooked up to my DC. If you don't have a DC, below is the cheap way many start: two bag dust collector from HF (you can get them for $130-160 on sale), with a Wynn canoster filter added ($90 or $130). It moves an incredible amount of ar. You can spend alot more money for pretty much the same thing.
Sounds good. What is the electrical service required? Will it pick up metal dust from metal working or is this a fire hazard? I think I could put this in the attic. Is that OK? Shop space is valuable, attic space is not so much.
   / Garage for Power Trac and Shop #25
Bob,
The metal chips, dust, etc can be best picked up by a magnet. Keep that stuff separate from the wood dust.
I would not put the dust in the attic, or in the shop. Outside under an overhang. That fine dust out of the bags have to go somewheres, preferably not back in the shop .
I put a cement pad in years ago planning to build a garage/workshop, and installed a 6 in pvc tube under the pad from the middle of the shop floor. going to the back the garage/workshop just for dust or dirt or thrash.
   / Garage for Power Trac and Shop #26
All interesting stuff / reading. I have the same space issues out in my two car garage, and plan on building a small shop out back this summer. 25 x 25 is more what I had in mind, interesting people saying this is too small. :eek:
I hate to block off any of my beautiful woods view with a shop but, I do a lot of wood working and need somewhere dedicated to that. I also a place to dedicate for working on tractors and such. I was thinking a 25x25 with a second level small room.
I'm tired of wood dust getting into everything and have no room to maneuver during the winter unless, I move a couple of tractors outside. When I do that I need to open the garage door and this lets all of the heat out that I had built up. I was also thinking of using my large Shop Vac to help remove dust since it´s just sitting there taking up space anyway. :cool:
   / Garage for Power Trac and Shop #27
J_J said:
Bob,
I did that also in my shop only I used a 4 inch pvc pipe where my table saw was going to set I have a blast gate where it comes up out of the floor ,it works good with no problems with it. I also ran the electric cable along side the pipe and up beside the pipe that way I don't have an electric cord to trip over. I also put drop down plug ins where the machines would set that an electric cord wouldn't interfere with using the machines. Talking about picking up metal with the dust collector, I wouldn't want to do it instead a magnet does a good job. I have three 55 gallon barrels in line just before the suction lines go into the collector most all of the dust stays in these barrels and don't go into the dust bags but still I scringe at the thought of something big going into the collector and ruining the impeller. Someone said that the thin walled pvc would collapse, I haven't had that to happen. If you are going to use pvc for your suction line I have read that it is a good idea to run a wire along side the pvc pipe and grounded to the machine it is on and to the plug in box to keep static electric from building up and arcing and starting a fire. The first time I set my dust collector up I had the wire inside the pipe but now I have it on the outside with a screw at each end of the pipe joints with the wire wrapped around it.
   / Garage for Power Trac and Shop #28
You guys seem to have some pretty good systems going.
I am going to finish off a part of my basement for a workshop, so...
Pics! Lots of Pics, sure would help me out if you guys have any.
Thanks,
Abe.
The information that I am getting far exceeds my wildest expectations. Keep it coming. As Abe says, pictures would be good. I am thinking about the 2 HP 2.5 micron dust collector from Grizzly.
I am planning to use a wood stove for heating. I am tending towards a good quality one (about $1500 dollars, EPA approved, 70% efficiency, lower clearance), versus the Northern one (about $600, EPA excempt, unknown efficiency, greater clearance), My main rational is efficiency and clearance. I figure I am paying about $50 per square foot, so the stove is cheap compared to building a larger garage. Any comments on this?
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
(16) 12" CHANNEL IRON (A57192)
(16) 12" CHANNEL...
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
2020 Peterbilt 367 (A55973)
2020 Peterbilt 367...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2014 Ford Taurus (A56859)
2014 Ford Taurus...
