Garage Construction begins
/ Garage Construction begins #2
Pretty neat idea with the electric winch on a boom pole mounted to the tractor. Just to be safe, I probably would have put a large rock in the loader bucket.
That is one big garage, it's looking good.
/ Garage Construction begins #3
Nice pole you got there 7mm. :) Sweet setup. Looks like it works fine as long as you keep the angle of the boom steep. Did it rock the tractor at all?
The crane pole worked better then most of us thought. Was it safe, probably not, did it work....yep. Would I use it again for something similar... absolutely. The tractor was solid, the first thing came to mind was to put counter balance weight in the bucket, but after a few test runs it was fine. I think since the pole was fairly close to vertical most of the weight was put on the 3pt. Now if I had that pole closer to a 45' angle it may be a whole different story.
I used the FEL to put the upper trusses in place then turned around and used the pole - 3pt to lift them. I didn't want to take the chance moving around with alot of weight hanging from the pole. Plus, I used a General Purpose 3k winch, they say you are not supposed to use them for hoisting. It seemed to work fine but we didn't trust walking under neath of it.
Building is 30x36, 14' eave and 19' peak. I didn't realize how tall it was going to be until I started putting this up. My main concern was is the bay garage door going to be tall enough to bring the tractor in with out folding down the ROPS. But after seeing it up, it doesn't appear to be a problem.
/ Garage Construction begins #5
NICE JOB 7mm! A heckuva family outing :)
Your tractor will fit ez, my shop is 14' eaves too, with 10'W x 12'H doors, plenty of clearance.
You're going to fill that big shop up in no time, there's never enough space lol.
John Deere 700 H Dozer (A62679)
John Deere 700 H...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
JOHN DEERE 5075E TRACTOR (A64278)
JOHN DEERE 5075E...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
Blender Trailer (A64194)
Blender Trailer...
