Gambled on a G5200 Today
   / Gambled on a G5200 Today #1
joleat
Kubota G5200H
Without doing much research on the G5200, I took a gamble on one today for $1300. It has 1235 hours and looks better in person than it does in the picture (seller's picture). I need to clean it up a bit and snap a few pictures of my own before I dive into maintenance.
My old Cub Cadet LTX 1042 is on its last leg, so I've been keeping an eye on marketplace for a couple weeks. I didn't have a particular model in mind, but I knew I wanted to move into something more robust. I was watching for a Gravely or an old Ford, but had hopes of maybe landing on a diesel Kubota or Deere. Time will tell if the gamble was worth it.
I look forward to learning about it. If anyone has experience with this model and wants to share anything I should know, please feel free to do so.
   / Gambled on a G5200 Today #2
Good lookin machine there. Looks like it's all there. Many times on old machines all the missing things are the hardest thing to go through. And you're right that is a FAR more robust machine than the little Cub you're replacing. These Kubotas are like tanks. Thick steel, heavy drive shafts grease fittings everywhere you look, and they weigh way more than you might expect. Mine (G2160) replaced a nice little Honda 4514 (really nice little machine like a tank in it's own right) but just the mower deck from my G2160 weighs almost as much as the entire Honda machine did.
Of course I am really feeling that weight and size at my age.
In any case you will grow to love the music of that little diesel humming away as well. Congrats on the "new" machine.
   / Gambled on a G5200 Today #3
I bought one new in 1993, I now use it occasionally, just because I like running it. A BX2380 and a B2650 with a rear finish mower do the job most of the time.
Thanks all! Like Tractor, you have a real gem there!
The guy I bought mine from told me it can be a bit difficult to start after being parked for a while. According to him, the original owner told him it's been like that for a while. Sure enough, it took some cranking to get going this evening, but I was able to fire it up without starting fluid. I suspect maintenance has been deferred for a while. The guy I bought it from bought it last year, but he is disabled and it was just too much for both him and his property.
I snapped a few more pictures when I got in from work. I haven't had a chance to do anything to it yet, so these pictures represent the condition it was in when I bought it. It was, at least, garage kept, so it's in pretty good condition in terms of looks.
So far, I know I'm going to be looking at new tires (dry rotted), new filters, and new fluids. The steering has a bit of slop, but nothing compared to the Cub Cadet being replaced. I can live with it for now. I need to dig into the PTO lever linkage and belts to see what kind of adjustments can be made. At this point, my seat time is obviously minimal, but I noticed the deck belt sometimes still receives slight power with the PTO lever in the disengaged position.
   / Gambled on a G5200 Today #6
Word of caution NEVER NEVER NEVER use starting fluid on a Kubota engine. Even the tiniest hint of it will ruin the engine.
This gamble may not pay off.
It took a couple minutes to get it started this evening. Once again, without ether, but man it took a while. The battery is good and it seemed to crank fine. It had a periodic puff of white/light gray smoke, but most puffs were black. Prior to starting, I held the key in the glow plug position for at least 30 seconds -- the glow plug indicator didn't illuminate.
So here's where I am...
When I first got to the seller's house, he told his grandson to stay off of the tractor because it was hot. However, it wasn't running at that time. I didn't think anything of it because he may not have wanted his grandson to climb on it or maybe he had just moved it out of the garage and it truly was hot. I hate this feeling, but he knew I was on my way and it sure does make sense now that he brought it to temp before I arrived so the rings would expand (raising compression) and it would be easy to restart. And it was. I shut it off and restarted it a couple times and it was immediate.
I don't have a compression gauge capable of 400+psi. Local parts stores only have compression check kits for gasoline engines (250-300psi). Harbor Freight is a little out of the way (over an hour), but they have a diesel compression kit for $99. That may be my next move unless someone here has other suggestions for troubleshooting.
It looks like rebuild kits are $400-$600, but I don't know how far down the rabbit hole I want to go since I'm already in it for $1300. Fluids and filters will put me around $1500, so I would be in it over $2000 after a rebuild. That is assuming I can call in a favor from a diesel-loving family member to assist with the rebuild.
Thoughts? Well wishes? Haha.
   / Gambled on a G5200 Today #8
Don't be throwing the baby out with the bath water just yet. The hard starting may have nothing to do with a bum engine (unless the previous owner had hit it with ether). It's well documented (including in the manuals) to never hit them with ether. If someone did pretty much guaranteed something in that engine is bent.
But I'd gamble on a compression kit $100 is pretty low risk) and check it out.
Watching with popcorn
I appreciate your optimism. I'm definitely taking a glass half-empty stance at the moment. The fact that the seller told me it can be difficult to start, and the original owner told him it had been difficult to start for a while, makes me lean even further toward the rings being either worn naturally or cracked from ether starts. Ether is the "easy" way, so I wouldn't be surprised at all if one or both of the previous owners used it.
I wish I would have put this all together before buying it. I was just stricken by the fantastic appearance and figured the difficult starts were from glow plugs, clogged filters, or something else that would be easily solved. I really do hope I'm wrong about the rings.
   / Gambled on a G5200 Today #10
I sure hope not for that little diesel's sake. Because if you can get it sorted out they make nice "music". Good luck waiting to see what you find out
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2015 VOLVO VNL760 SLEEPER (A57880)
2015 VOLVO VNL760...
2016 John Deere Gator (A55973)
2016 John Deere...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56435)
2007 Heil Heavy...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
