Gaining oil
/ Gaining oil #11
Sometimes we get a bit complacent. We are all led to believe it’s diesel. But how is you hydraulic oil level? If by chance that’s what’s getting into your crankcase your sump may be getting low. Just thinking without any outside influence. Good luck mann
/ Gaining oil #12
Have you checked the diaphragm in the mechanical fuel pump?
/ Gaining oil #13
I have a similar issue on my Bobcat 331's Kubota 2203. Getting a new lift pump first. $20-50 for a fried rice version NO!, $120-135 for genuine Kubota YES!, plus s&h. $216 from Mess... My hydraulic pump is attached with a bell-housing with no apparent way for hyd oil to get into crankcase.
/ Gaining oil #15
B20 Kubota TLB. It was gaining probably an inch on the dipstick in an hour. I replaced the fuel pump with an oem from Coleman's Kubota. Still gaining the same. Next I removed the injection pump and took it apart and didn't see anything wrong with it, just cleaned and reassembled it. Put it back on and used it for two or three hours and it didn't gain at all. A couple days later I used it and it gained about half inch in probably three hours. It's a cast iron Diesel Kiki pump. Any suggestions on what to do next would be greatly appreciated.
If it looks clean, bottle it and make more. With the price of oil these days, you will have the magic oil making machine as an oil tycoon.
/ Gaining oil #16
Draw an oil sample and get it analyzed. That will tell you what's in the oil so you don't have to guess.
Is that true? This is diesel, not gasoline. I think their primary means of detecting diesel in crankcase oil is a simple viscosity test, which could be reading low due to other factors, such as low-viscosity hydraulic oil in the crankcase.
Are you actually sure that they can differentiate diesel from low-viscosity hydraulic oil, in a standard oil analysis test?
/ Gaining oil #17
To make sure it’s diesel, lay a paper towel on a clean flat surface, pull dipstick and “flick” dip stick at the paper towel. If there’s diesel present, it will run outwards from the middle of the oil stain.
/ Gaining oil #18
Why does this remind me of checking for cerebral spinal fluid in the blood of trauma patients.... :)
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2019 Ford F-550...
CFG Industrial MX15RX (A60463)
CFG Industrial...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2006 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2006 BIG TEX 20...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
