Loader g3033 loader bolt torque
/ g3033 loader bolt torque #1
fcajr109
Ontario, NY
LS G3033
I just bought a 2012 g3033 tractor w/loader, and I've read that the loader attachment bolts need to be torqued regularly. Does anyone know what the torque value is, and how often this needs to be done?
/ g3033 loader bolt torque #2
On my 3104 loader the book has: if wrench size is 21 mm then 80lbs, if 24 mm then 125lbs, if 27mm then 172lbs, if 18mm 50lbs. This are for GRADE 8.8. If grade 10.9 then 21mm/111#,24mm/173#,27mm/239#,18mm/70#. hope it helps.
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
YALE FORKLIFT (A63291)
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
2016 Ford F-550 4x4 ETI ETC37IH 37ft. Insulated Bucket Truck (A64556)
2016 Ford F-550...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A64556)
2013 Mack CXU613...
