FX24D throttle friction
/ FX24D throttle friction #1
bacrow
Bronze Member
Springfield, MO
New Holland Workmaster 33
The previous owner cobbled together the throttle assembly. I will try to post some photos tomorrow. The throttle is held closed by a spring attached at the throttle valve and then on the hose clamp on the fuel line from the injector pump to the fuel tank. The throttle does not stay in place. I assume there is supposed to be a friction place somewhere in the throttle controls, but I think it was removed.
Can you describe what it should look like, or do you have a photo or drawing of the throttle assembly (specifically the friction mechanism)?
Thanks!
On a separate note: what is the best way to clean the fuse box? Mine is full of brown fuzzy gunk that does not wipe out easily.
/ FX24D throttle friction #2
I will attach the page out of the parts manual. The friction washer is #7. The assembly has double lock nuts #12. I remember GW's was pretty much stuck but with a little penetrating oil and working it started working pretty good. Not real easy to access this assembly but I'll be suprised if it isn't on yours. A little hard to find. I'm sure you know the hand throttle is what utilizes the friction plate and the foot throttle just releases it back to where the hand throttle is set. Not sure I'm making sense. :confused:
How about removing the fuses and using a small delicate wire brush in combination with a contact cleaner.
/ FX24D throttle friction #3
I made a friction disc from sheet rubber, I think the variety intended for a tire patch. That was a mistake. It got gummy and sticky and oiling it didn't help.
Then I made one from synthetic rubber gasket material. (Butyl??). This has been in service a year and works just like the original one did - before it split and worked its way out.
I saw that you made one when I searched the previous posts. Did you buy the material, or did you source it from your home inventory?
/ FX24D throttle friction #6
My yanmar recon had rubber from an innertube as the friction thing when i bought it. This was straight from VN. It never worked, i fought with it all the time and the 2 jamb nuts.
I bought more nuts taht were not painted over and got the correct friction disks from Hoye on an order i made one time and have not had trouble with it since, other than the nuts vibrating loose once or twice in the last few years.
I will attach the page out of the parts manual. The friction washer is #7. The assembly has double lock nuts #12. Not real easy to access this assembly but I'll be suprised if it isn't on yours. A little hard to find. I'm sure you know the hand throttle is what utilizes the friction plate and the foot throttle just releases it back to where the hand throttle is set. Not sure I'm making sense. :confused:
I opened it up to take a look. I am missing the double lock nuts. Do you have any idea of the size of the nut?
/ FX24D throttle friction #8
The size is indicated on the parts list. 12mm. However, it does not give the pitch. That part number crosses over to this steering wheel nut but it doesn't show pitch either. I find it interesting Hoye sells this nut for 96 cents and some sights are selling it for nearly $10. Sort of like price gouging. Having said all that you could most likely look at the threads closely or measure them and determine the pitch. Then most likely buy it at Tractor Supply or a Hardware store. Yanmar Tractor Parts: STEERING WHEEL NUT _
Thanks, I wasn't sure if the 12 was a size or just some other reference. My other method was to try all of the standard nuts that I had in inventory and guess at the metric size in between the one that was too big, and the one that was too small.
I have had the best luck for metric hardware at the local Ace Hardware store. The big box stores don't have much metric selection, I don't have a Tractor Supply nearby, and the other farm supply stores don't have as good a selection. I will try there before I spend a buck plus shipping for a little nut from Hoye.
/ FX24D throttle friction #10
I used a half inch nut in a pinch, coarse thread. Didn't tighten too much. I think its 12 coarse but go to a nit place where they sell thepound like TSC and just get one of each type
,don't just ship the nut unless your ordering other stuff. I'm not sure if I got mime at hour or local? If I for hoye nuts they were thrown in on another order. I think I just got them at car quest. There a standard metric nut nothing special! .
/ FX24D throttle friction #11
If you have NAPA near you they should have metric nuts. Buy 1 each of the different small sizes ( 8,10,12, etc). They shouldn't cost too much
I tried the standard 12 nut. Now the issue is that the shaft is rusted and stripped. When I tried to put the nut on it was cutting new threads. I was afraid to break the shaft and not be able to replace it, so I stopped. I might have to try to cut some new threads.
/ FX24D throttle friction #13
I think a 12 is the nut? i wonder if someone put a 1/2" on it in the past and it cut new threads and now the 12 is trying to return back to 12???
It's worse than that. Some areas are completely flattened, and everything is rusty. I will try to get photos tonight or this weekend.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2017 Caterpillar 308E2 (A60462)
2017 Caterpillar...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
(250) Iranch Safety Traffic Cones (A60463)
(250) Iranch...
