FX24D issues
   / FX24D issues #1
coolbrze
VA
Kubota MX5800
I've got an FX24D & the tractor "pulsates" when running. Hard to describe but it feels like a steady shake every second or two. Any ideas?
   / FX24D issues #2
is the 3pt dropping a bit then suddenly raising?
   / FX24D issues #3
What do you mean by "running"? Is it moving, just sitting idling, hydraulics working?
   / FX24D issues
When it's sitting idling still although may do it when moving but if so, it's harder to notice but I'll pay more attn. next time I drive it. Hydraulics work but bucket doesn't stay up very well once you put weight in it...
   / FX24D issues #6
does the 3pt stay up when the tractor is off?
   / FX24D issues #7
1. Have you cleaned the Hydraulic filter screen lately? Its located on the under side of the machine
2. Also it sounds like your 3 point adj arm is out of adjustment, did you turn on it with a wrench where it comes out of the tractor top end?
3. Did you turn the 3 point adj knob, its located right between your ankles when seated on the tractor.
4. Do you have the correct hydraulic filter installed, ( if not) it will pulsate because its not circulating enough fluid.
Lots of questions...
   / FX24D issues
Sorry for the delayed reply, been busy working. No the 3 point hitch goes down almost immediately when I turn the tractor off but the FEL stays up.
   / FX24D issues #9
Have you checked the 4 things mentioned in the post above?
   / FX24D issues #10
my 3110 does this. I think it's the 3 point valve. I haven't replaced it yet. Last I checked, they didn't have any
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
Chery 7' 32 Drawer Workbench (A50121)
Chery 7' 32 Drawer...
Veshai PWS-100 2,200lb Electric Pallet Jack (A50322)
Veshai PWS-100...
2019 Bobcat S595 Skidloader (RIDE AND DRIVE) (A50774)
2019 Bobcat S595...
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
