FWD not working
/ FWD not working #1
wv1720
West Bygolly
Ford 1720
I need a little help on my Ford 1720. My FWD is not working properly, the front wheels do not engage. Where is the first place I need to start looking for the problem? I suspect something wrong in the linkage, maybe the shift fork/idler gear is not engaging correctly. Can I access this area by removing the top cover? Any ideas? Thanks
/ FWD not working #2
I would start by draining the oil from the trans. Then remove the lower gear assembly from the bottom of the trans.This is the part the rear of the drive shaft goes into. After loosening this pull it down and slide it off the drive shaft. Look at the gear and make sure it has all the teeth.See if you can turn the drive shaft. If you can and the wheels don't turn the problem is in the front axle. If the front wheels turn when you turn the drive shaft the problem is in the trans. There is no adjustment on the linkage. If you don't have a service manual, get one before going any further.
Bill
/ FWD not working
Thanks. Thats the first thing I thought about doing. But figured I wouldn't have to drain the oil by going in through the top. I'll pull that gear assy then jack up the front wheels to see if they turn with the shaft.
/ FWD not working #4
Just checking to see if you got it apart and what you found.
Bill
/ FWD not working #5
Your driveshaft to the front wheels probably has a splined sleeve/collar on each end. I'd remove the covers and check to make sure one of those collars has not slipped due to a broken rollpin or something similar. Check the simple stuff first before going to the more complex stuff.
/ FWD not working #6
Jim, If the 1720 is the same as my 1900 you have to drop the lower gear box to remove the tube that covers the driveshaft and couplers.
Bill
/ FWD not working #7
Bill
They don't make it easy, do they? Mine has covers on each end of the driveshaft housing. I assumed that all were that way. Bad assumption. . . .
EDIT: Bill, I went to NH's website and looked at the front axle parts diagram (attached). The part that can be removed is 42/43 to see if part 39/40 are in place. I could not find a diagram that shows the rear of the driveshaft, but on my tractor it's the same.
/ FWD not working #8
The next step after checking the driveline couplers is to remove the 4WD shift cover from the right side of the rear axle center section housing. You can check the shifter, fork and sliding gear before draining ALL the oil and removing the drop box. Draining some of the oil may be required to remove the shifter.
Relative to the driveshaft couplers, after you remove the two parts of the split shield, you can slide the long tube from the drop box housing to examine the rear coupler. The tube seals with an o-ring, but there should be no oil or other surpirses when you slide the tube forward.
/ FWD not working
Thanks for all the great info guys. I have not had a chance to look at it yet. I have a nice long weekend coming up, hopefully will have some time to do this. I'll be sure to report my findings.
/ FWD not working
Well, I found my problem. When I bought this tractor a couple of months ago, it was in FWD. It had been driven by an older lady until she passed away. Anyway, I can assume that it had been in FWD for a long time. Anyway, I took the driveshaft off, the front coupler was very worn. The driveshaft side of the coupler was fine. The pinion (#29 in diagram above) side of the coupler was worn completely smooth and the splines on the pinion are worn/rounded to one side.
The coupler is cheap, the pinion is not, $650.00. I will buy a new coupler and see how everything works. If I do need to take the pinion out, is it difficult. Or will it slide out of the axle case by removing the nuts on the pinion?
Thanks.
/ FWD not working #11
Hopefully the coupler will fix it. The pinion and ring gear come as a matched set and both need to be changed which makes the job more complicated. I know it's not the correct way to fix it but what if you welded the coupler to the pinion. You have nothing to lose since the pinion is shot.
Bill
/ FWD not working
Thanks for the input HP. Welding the coupler and pinion together was an option I was thinking about.
/ FWD not working
Well, the option of welding brings up another question. I do not own a welder. I could rent one to do this job. What type of welder would be best. I have welded before with arc welders, very limited experience with MIG/TIG. Any special rod/material to use?
/ FWD not working #14
For the cost of renting a welder, you could probably find someone to do it for you. Then you'd have a professionally welded piece.
2025 Hydraulic Tire Lifter Skid Steer Attachment (A66734)
2025 Hydraulic...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
165 GAL WATER TANK (A68842)
165 GAL WATER TANK...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A66736)
2016 Peterbilt 579...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
2014 DIAMOND C 45HDT CAR HAULER (A67714)
2014 DIAMOND C...
